  1. Any one experience this? I burned "Heat" and checked 2 ch for the movie. After the backup was finished (after 1.5 hrs), I played the movie and there was no audio. Glix in the burn? Anyone else have this problem before?
  2. Member wulf109's Avatar
    Jul 2002
    With most versions of DVD Shrink you must keep audio stream #1 or you will hear no audio. The audio you saved is there you need to cycle thru the audio streams to hear it.
  3. Seems like in the "Menu" part, you almost always have to click 2 ch AND 5.1 ch since some parts are either or. Certain sections of the menu are only 2 ch while other parts are only 5.1 ch....not sure why its laid out that way.
  4. i think i'm having this problem. all my copied dvds work fine in my dvd player, but not on my PC. i'm using windows media classic. the audio says 'english, MPEG1 48000Hz 16bits 2 channel(2)'
    is there anything i can change on media player to get the audio working?
