The only way that I can delete any thing(file or folder) is to select the file for folder hold down the shift key while deleting. That works. If I try to delete inside a program like Thumbs the program disappears, the screen turns white and then goes to the desktop. So it looks like I can only delete files and folders while in explorer. Any thoughts on this?
To Tommyknocker
The only keyboard function involved in this is the shift key. The winxp delete function simply doesn't work unless the file or folder is selected then press shift key, right click the file or folder and then it deletes ok. It deletes ok using cmd and also dos, but not windows.
Cut and paste works ok and emptying the RecycleBin works ok. Hope this helps.
XviD4PSP & Avidemux Doesn't work for me anymore.
By The_Jelly in forum Newbie / General discussionsReplies: 15Last Post: 14th Mar 2012, 08:05 -
Windows Media Server on PS3 did work, suddenly it doesn't
By sshortty in forum Media Center PC / MediaCentersReplies: 1Last Post: 13th Feb 2011, 10:59 -
dv capture and playback doesn't work anymore (except in quicktime)
By richardlode in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Jun 2008, 01:22 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
Philips DVDR7310H: search (Guide Plus) doesn't work anymore
By Monco in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Aug 2007, 12:05
