Hi!
Sorry if I bypassed any information regarding this, I just could not find it.
Does anyone know how to convert Real Video format (.RAM) to .mpg?
I have just been through the same problem and found only TWO successful methods:
1) Yep like Redwudz says, EO Video - BUT this will cost if you want to use it past the 30 day trial...
2) Can you play the Real Video format in Media Player? (If not install the correct codecs)... If yes, use AVISynth to frame serve it to your usual conversion program that would normally not accept it, such as VirualDub!
Bonus - this method is FREE!
Andy.Work you bloody thing.... -
If you install real alternative-avisynth 2.5.4 will load both video and audio for you and you can frameserve straight to TMPGEnc or the Main Concept encoder.
However, this works only with Real Video 9 and 10.
For older vids (normally the ram extension indicates an older vid)-Real7ime Converter(free!!) works well-provided you have either real alternative or Real One Player and earlier!!-Does not work with latest Real Player.
Be sure to choose compression-none for audio-video part works with Huff,PICVideo,vp6-codecs(tested).
It needs I420 driver installed. If you get error saying-no decompressor found. Look for the Intel I263 codec on Google for your OS and install. The I420 is automatically installed. It will work after that.
How to Convert RMVB(Real Media Variable Bitrate) to AVI
By deletrius in forum User guidesReplies: 62Last Post: 5th Apr 2011, 08:36 -
How to convert and burn a quality DVD from Real Player (.flv) download
By elaway in forum Video Streaming DownloadingReplies: 1Last Post: 17th Jan 2010, 17:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05 -
Convert Quicktime to Real Video 8 - OSX
By forsterr in forum MacReplies: 2Last Post: 15th May 2007, 11:40 -
Getting 0KB files when trying to convert Real Video to other formats
By j1201 in forum ffmpegX general discussionReplies: 1Last Post: 13th May 2007, 04:34
