I just made a DVD using Ulead MovieFactory 8.0 trial on a DVD+R disc (Ritek +R). There is no problem to play the disc on PC using InterVideo WinDVD but there is no audio at all on my DVD player. The DVD player is kind of old, Nintaus N926 (a chinese company), bought in 1999. The player cannot play dvd+r discs, or my authoring has some problem? What causes the problem?
BTW, I've backed up some DVD videos using DVD-R discs (verbatim MCC) by the writer (Oporite DD0201) and the player can play these discs.
Thanks a lot.
your player maybe doesn't support dvd with mpa/mpeg audio, check your dvd player audio settings if you can change any mpa/mpeg audio settings.
or else make a dvd with lpcm/wav audio or ac3/dolby digital.
Ulead DVD MovieFactory 6 not making maximum use of DVD space
By GSP_87 in forum Authoring (DVD)Replies: 6Last Post: 6th Nov 2009, 05:54 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 05:05 -
Ulead DVD Moviefactory 6 Plus (trying to get to grips after UDVDWorkshop2)
By dvdfever in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2009, 21:01 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 11:46
