  1. I recently built my grandson a computer for playing his games because I don't like games on my computer (don't play them, don't like to waste the space).
    His recent favorite is "Enter the Matrix". He is seven years old. Today I noticed the 'Play' disk was really in bad shape (severe scratches, food particles, etc). I decided to make a copy while it's still readable. However, the copy doesn't work. The computer recognizes it but it doesn't initiate the game. I suppose there is some type of 'protection' at work here. Does anyone know what the secret is?
    If it works, don't fix it.
    Nov 2003
    Houston, TX
    nowaday i haven't been able to just copy the files and folder to the hd then burn a sepperate cd, but what works sometimes is make an image of the cd and mount it with daemon tools.
    josh
  3. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    Gotta have something to remove it's copyright protection. Also Make sure if it's a DVD game you're using DVD media to burn it. Sometimes the size may not be compatible, but usually the software you use tell you this and won't do the burn. It may not be the problem, and these solutions may not work, but it's worth a shot. But you'll probably find the main issue is the copyright protection.
  4. Member Keefkey's Avatar
    Apr 2004
    Hull, UK: Not near London
    You could try using A-Ray Scanner v2.0, this program checks discs for various types of copy proctection http://www.aray-software.com/ At least you'll know if the disc is protected or not.
    Wrap the tape firmly around the hamster...
  5. Originally Posted by Keefkey
    Sweet program, Thanks
  6. Member Keefkey's Avatar
    Apr 2004
    My pleasure
