  1. I know it's a dumb question, don't ask
    For my own knowledge, if I were extract either the FS or WS movie from a dvd, which would be larger in size? or are they the exact same?
    This is why I ask: I was coverting a FS movie to xvid, and was questinging myself... 'if I have the WS version, would I be able to encode a better picture/bitrate because I have 'less' of the movie on the screen?'
    The answer to my own thought would be, yes. I don't know why, maybe because I only see 'half' the picture in a WS oppose to a FS, but that is my only reasonign
    I don't own any WS movies, that's why I ask
  2. Banned
    Jan 2004
    Going in Circles
    No
    Aspect ratio is what you are talking about.
  3. Originally Posted by X-treme
    Your reasoning is wrong. Give this a quick look. You'll see that with fullscreen, almost half of the picture is cropped out, only horizontally (not vertically like you had thought).
    Apr 2004
    The bottom of the planet
    With any compressed video format, the only relation that picture size has to file size is that the difference between the size of the video window and the picture will affect the compression ratio. A 1.78:1 video in a 16:9 Enhanced frame will require more bits than a 2.35:1 video or 2.55:1 video (or 1.66:1 video for that matter).
    Another reason why widescreen is the only way.
    "It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
