I have followed the instructions at the bottom of this page to the letter but can not get images to post when I start a thread or when I reply. Yes the file size is less than 50kb and the file format is .jpg. Here's what I am doing, please tell me what I am doing wrong. I type in the below info:
[img]https://www.videohelp.com/forum/images/guides/p972044/cis1.jpg[img]https://www.videohelp.com/forum/images/guides/p972044/
Please help me if you can, I would really appreciate it. Thank you.
Results 1 to 9 of 9
Thank You,
GolfNut -
At the end of the link, it should be[/img]intead of [img]https://www.videohelp.com/forum/images/guides/p972048/
gitreel, thanks for the reply, just tried that and all I get on my post is a red "x" in a square box, no picture?
Thank You,
GolfNut -
Are you trying images saved locally or images on the web?
it should be
go into the body and do the brackets thing,
then scroll down where it says upload image, browse for the image and say open. Then you submit and it should work.
forum post attachments disallowed
By davexnet in forum FeedbackReplies: 2Last Post: 18th Nov 2010, 18:42 -
How I modify in forum archive my old post?
By roma_turok in forum FeedbackReplies: 6Last Post: 17th Jun 2010, 10:35 -
Is it possible to embed flash video into forum post? [Solved=Yes you can!]
By freebird73717 in forum FeedbackReplies: 15Last Post: 7th Mar 2009, 12:36 -
What forum should I post in?
By ne_plus_ultra_1 in forum FeedbackReplies: 1Last Post: 3rd Sep 2007, 12:54 -
DUnno where to post this but since this is audio forum...
By faramith in forum AudioReplies: 4Last Post: 28th Jun 2007, 02:40
