ive got some files i need to convert, they are divx codecs.
i turned them to dvd mpeg2 pal using no1 video converter, but the file went from 350mbs to 2gigs as a mpeg2, not to mention it took 3hrs to do.
what i need is. what can i convert them to thats smaller, but will run on a stand alone dvd player.
i only have a cheap dvd player, which doesnt support divx, nor does my dads.
Results 1 to 12 of 12
Try the guides section:
https://www.videohelp.com/convert#4;10
I'd suggest this guide:
http://www.lancey.info/tutorial/divx2dvd.html
As far as the MPEG-2 files being large goes, they are meant to be. MPEG-2 is nowhere near as efficient as MPEG-4 at compressing video, so the files will be larger as a result. Two hours to a DVD (4GB or so) is acceptable.
With regards to the conversion time, it takes me twelve hours or so to convert a couple of hours of video to DVD since I use very high quality settings. Video conversion takes a long time, and this is unavoidable.
Hope this helps,
Cobra -
whats the diff between dvdmpeg 2 and standard mpeg2 cos the no1 video converter also does that
For the fastest way to do it, I'd use a program from the link that Baldrick gave. I personally use the Nero Express 2, since I already have it. Gives acceptable quality in a reasonable amount of time.
Blah, blah, blah -
murderous,
Over on your left-hand side, you will find a wealth of information. Have a read, and a lot of your questions will be answered.
MPEG-2 is the same for anything - be it files, SVCD, XSVCD or DVD. However, things like resolutions and framerates are different due to the standard each format must abide by. MPEG-2 is simply the compression used. MPEG-1 is VCD, and MPEG-4 is found in AVI files etc.
TMPGEnc is fine for converting to DVD-compliant MPEG files, and does take longer than a lot of other packages but yields very high quality. As nufan292 has suggested, Nero can also do this but I have personally not tried it and so I cannot recommend it.
Please do some research and you will gain a lot of valuable knowledge, and you won't have to keep asking these questions on the forums.
Best of luck,
Cobra -
ok thanks cobra.
i just not a reading person, well except reading stuff for over 18.:P -
one other thing.
the divx fiel goes for 42mins, but the mpeg only goes for 14mins and the just stops. -
Open your original AVI file in VirtualDub and select "Scan for bad frames". I suspect that a bad frame might be stopping TMPGEnc dead.
Cobra -
oh sorry i havent gotten around to that program yet, im in australia, an i have had a busy weekend.
i was referring to when i used no1 video converter it only did 14mins worth -
Scan for bad frames.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 10th Apr 2009, 00:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 01:17 -
Burn in subtitle in a AVI div-x film
By aslan in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2007, 11:02
