Hi,
i've tried to load two AVI files into PVS9 with the intention to merge them and ctreate an SVCD. the original version of the avis is probably a dvd. the size of the avis are ~800 Mb (does it even matter?).
the PVS9 provided an error message instead of loading. theoretically it should work - am i right?
thx
q
Studio 9 uses type 2 avi. If you're trying to load type 1 avi's, then no they won't work. Both Canopus and Ulead make a free file converter that will convert type 1 avi to type 2 avi. Try going to their web sites and download one or both.
If the original version is on a DVD and you can play them on a DVD player, their not in avi format, but mpeg2 format. Unless of course their stored on a DVD in avi format as data storage.Geronimo
pinnacle studio 14, more light in a video?
By computer4 in forum EditingReplies: 3Last Post: 16th Jan 2012, 09:02 -
Pinnacle Studio14 HD>AVI Files from Canon G6 cannot be Imported into STUDIO
By rivrbyte in forum Capturing and VCRReplies: 2Last Post: 11th Sep 2011, 14:13 -
Pinnacle Studio 12 and AVI H264 NTSC
By slalomchip in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2011, 19:47 -
AVI on Pinnacle Studio 14
By jhughes2466 in forum Video ConversionReplies: 4Last Post: 8th Nov 2010, 05:12 -
Trying to edit avi in Pinnacle Studio: PROBLEM!
By L3Wi5 in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2008, 12:09
