Im trying to convert an mov to dvd but its got a video resolution of 865x368, 16:9.
Im trying to find out what would be a good video resolution conversion from those numbers.
I usualy convert from avi but this one is different from the norm.
Thanks.
I'm a victim of circumstance
720x272 would be the nearest conversion.
I will give it a try.
I know theres a way to figure out the conversion but couldnt find it in the "guides" section.
thanks again.I'm a victim of circumstance -
I haven't found out how to conver it eitherOriginally Posted by tmgrood
I have .mov files that are in 524x360 resolution and want to lower it but don't know the optimal resolution. Anyone know?
Shouldn't the final res be 368 vertical encoded at 16:9 for NTSC or 432 vertical (from 435) for PAL?
272 is for a 4:3 encoding for NTSC.
As for the guides they are there <<<<<< you aint looking hard enough. -
What are you going to use to encode it to mpg? I use TMPGEnc and when I go to encode a 2.35:1 movie, which is what you have - I set the flag to 16:9 and custom clip the resolution to 720x360....turns out fine
"Hello. My name is Inigo Montoya. You killed my father. Prepare to die."
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57 -
Resizing video resolution and video quality
By Timex in forum Video ConversionReplies: 13Last Post: 23rd Aug 2011, 22:08 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
Video Resolution
By dazealex in forum ffmpegX general discussionReplies: 0Last Post: 15th May 2007, 15:46
