Ok, how the hell do I use this thing? I'd like to attempt to use it to reload a laptop computer that I can't find real mode drivers for. I can't even figure out how to get it to show up in windows...![]()
Results 1 to 9 of 9
OH my... You'll have to find some DOS drivers, and boot from a floppy to make it work for an install. And even then I doubt XP or 2000 will be able to use it to load the system. You might need to load win 9X just to be able to load one of the higher versions.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Anything on the Mfg site to support your endevour... I have the exact same problem with an old Iomega Parallel Zip Drive... Thank God Iomega has a driver for XP.... otherwise it would be in the trash.... only viable way will be to get drivers from Mfg. If all they have is a Win98, Me, 2k drivers... try 'em out.
I just discovered that his CD ROM is apparantly from a MAC.
Am I screwed? I'm hoping to hook it up to a laptop I have and load my WIN98 O/S....
Are you sure it is parallel and not 25 pin scsi ?
I have some cables that go parallel to scsi that use a floppy disc utility to detect and then modify autoexec.bat and config.sys file, copy drivers to hdd. utility has to be run each time a change is made in the scsi chain or what is in a box, cd or hdd
I have no idea where you would buy one or if they are still made/supported. I had/have some from Belkin and Adaptic
Pretty obsolete stuff now but worked ok for older laptops w/o cd and no usb
Also have a parallel to ide box that I have never tried. Found it in a close out bin and thought what the heck. -
Yeah, it's got the Centronics (?) connector. Like a printer.Originally Posted by snafu099
If it's an external CD-ROM from a Mac then it's SCSI. Older external SCSI hardware commonly used three different connectors - DB25 (same as a PC parallel port), HD50, and 50-pin Centronics (PC parallel printers use a smaller Centronics). The DB25 was used almost exclusively on the Mac, most PC and UNIX workstation interfaces used HD50, and external devices commonly used the Centronics.
A man without a woman is like a statue without pigeons. -
Ah, that cleared it up. I saw the connector and just figured it was the same parallel connector that was on my printer. Damn, that makes it pretty much useless to me...Originally Posted by sterno
You can probably find some kind of bridge adapter or a PC card to hook a SCSI device to your notebook, but it would probably cost you more than a new CD-ROM.
For what it's worth, a parallel-port CD-ROM would probably also be pretty useless to you. When I was doing a lot of PC support for a school (ancient PC hardware because they couldn't justify the cost of a new PC but they could justify the cost of my time) we had to use a parallel-port CD-ROM to load Windows on a lot of machines. We had to install DOS with the Backpack drivers and run the DOS-based installer from the CD. It would copy the installation files to C: and then reboot to actually start the install.A man without a woman is like a statue without pigeons.
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
Authoring targeting PAL and NTSC in parallel
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 16th Apr 2010, 02:48 -
How to merge parallel(simultaneous) video streams ?
By buddhikasgj in forum ProgrammingReplies: 0Last Post: 31st Oct 2008, 12:56 -
Any reason to continue using my parallel printer cable?
By zzyzzx in forum ComputerReplies: 25Last Post: 19th Jun 2008, 06:51 -
Video Conversion for Parallel/Gird Connected PCs
By Alterego in forum Video ConversionReplies: 5Last Post: 16th Jun 2008, 20:06
