If i created a DVD in DVD-lab 1.31 and DVD-lab Pro B3 from more SVCD's then i can play the VOBS individualy (by clikcing them) with sound,but if I use Video_ts.ifo to test de DVD then i get no sound.
If I play it in a stand alone player then no laguage neither, i can't change with the language button
Who can help.
BTW: If i use DVD shrink, then I don't see any audio tracks
Hello,
Why don't you try loading the vobs in tmpgenc to make sure the audio is intact? Load Tmpgenc, mpeg tools, demultiplex. Load video file. It shows the video and audio portions of the file.
At worst all you have to do is strip the video and audio and remaster the dvd. It's a pain but it will work. Hope this helps.
thnx 4 your answer, but the audio is still in de VOBS, because if i click them one by one al off them play the audio., but if id it's done by the .ifo file then i don't get the sound
Hello,
If the sound is there then maybe the authoring was wrong. You could try ifoedit to make new ifos. I'm not on expert on that but I'm sure there are guides here for that. Probably there was an error when it was created (the ifo doesn't read the audio? not sure, I'm not entirely sure how the two interact). Hopefully you can restructure the dvd without too much effort. Keep trying though.
Hello,
I'm sorry I can't help you with ifoedit. I've only used it a few times and not very successfully. I just suggested it because I know it's pretty versatile for ifo file creation. I suggest you comb the guides sections on this site for help. There should be info for how to create new ifos from exisiting vobs. Good luck.
Kevin
P.S. Sorry I couldn't help more, but like I said ifoedit is still a bit of a mystery to me.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
what kind of audio did you use? Ac3, mp2, ... 48kHz or 44.1? And is your DVD NTSC?
Maybe you have used wrong audiostreams.
How do I convert VIDEO_TS containing VOB, BUP, IFO files to a single file
By Firesmith in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2010, 11:14 -
How to repair dvd with corrupt sectors AND bad video_ts.ifo?
By Spixe in forum Authoring (DVD)Replies: 8Last Post: 25th Jan 2010, 07:54 -
How do I create VIDEO_TS IFO from VOB files
By stockton209 in forum DVD RippingReplies: 2Last Post: 8th Jan 2010, 03:07 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 10:39 -
*S.O.S* No Sound when burning VOB-IFO-BUP Files to dvd
By Zaii in forum Newbie / General discussionsReplies: 3Last Post: 30th Jul 2007, 04:46
