I use it to make sure the disc are much more resistant to water, just in case. if you get a single drop of water on one after printing it'll run like mad. just depends on who will be using the disc as to whether its worth it for you. I also think it gives a more proffesional look. the gloss makes it look like a store bought DVD. the Key is to mist a couple coats on from a distance. hold the can about 12-16 inches away and spray almost straight down with only a slight angle. keep the can moving too, don't ever let it linger in one place or it will build up heavy.
Results 61 to 62 of 62
burn first then print (then spray if you have to - I have spray but it's not clear to me the effect of the spray on the disk long term).Originally Posted by dydy
if you print first, you might scratch the disk which will cause big problems burning .. if you scratch the disk after burning, not as big of a problem as the player will correct for a small scratch when reading"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
Which Canon printer should I get to print on dvds?
By zanos in forum MediaReplies: 7Last Post: 4th Sep 2009, 19:58 -
Do you buy dvds/bluray from other regions besides your own?
By yoda313 in forum PollsReplies: 29Last Post: 11th Mar 2009, 19:36 -
Can't print on my CD
By Tom in HD in forum MacReplies: 5Last Post: 19th Sep 2008, 11:33 -
Print Post...
By X_Splinter in forum FeedbackReplies: 4Last Post: 9th May 2008, 11:18 -
Installed R260 Epson, and the print CD keeps recognizing my old R200
By faramith in forum MediaReplies: 11Last Post: 2nd Dec 2007, 19:29
