OK
I want to recompress a video file so that I can play it on my Yamada DVX Player.
The original file is an MKV source that contains RealMedia Video and OGG Vorbis Audio. The file is only 623Mb in size. This will fit on a single CD but for obvious reason will not play on the DVX player.
To recompress this file I am using VirualDub v1.5.10.1 frame served via AVISyth - a technique that works seamlessly.
The original movie states:
Video: RealMedia: 30fps, 2000kb/s max bit rate (I assume its variable)
Audio: OGG Vorbis: 48KHz Sterio
Question:
I am re-encoding to Xvid, 25fps 1500Kb/s with MP3 48KHz 192Kb/s BUT the resulting AVI is 1.6GB in size!!!!!!!!!!!!! And won't fit on a CD - (I have no DVD burner)
Attempting DivX encoding results in similar file sizes (obviously).
Is there something obvious I am missing! I expect the resulting AVI file (bearing in mind that MKV is slight more efficient) to be about 650Mb in size, not 2.5 times bigger than the original!
Cheers,
Andy
P.S.
How can I VBR encode an XviD / DivX / Audio MP3 ??
Work you bloody thing....
tried calculate the bitrate so it will fit??
www.videohelp.com/calc or www.videohelp.com/tools
Toast "An error has occurred recompressing the video"
By trevytrev in forum MacReplies: 12Last Post: 25th Feb 2015, 16:47 -
Cutting video sections with Virtualdub without recompressing
By rantpolicy in forum EditingReplies: 11Last Post: 16th Apr 2012, 06:48 -
Easy edit DVD video cutting out unwanted stuff without recompressing
By deadp0et in forum EditingReplies: 6Last Post: 7th Feb 2011, 07:49 -
Recompressing Audio Stream
By jdvideo in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2008, 18:04 -
Recompressing Audio
By usermm in forum Newbie / General discussionsReplies: 17Last Post: 8th Jan 2008, 10:12
