Hi guy's im useing dvd lab v1.3, this is why im puzzled.
i have menu 1 and menu 2 i also have 3 short movies, menu 1 has 2 buttons, "Play All" and "Episodes", Episodes is linked to menu 2, which has 3 buttons one for each movie, this is all ok.
I can get the play all button to play all the movies this is ok, but i cant seem to have both as soon as i link all the movies together for the play all, when i go to menu 2 and press the first button the movie plays but also the rest of them play cos they are joined for menu 1, im new to all this so can somone help me with this problem, im going nuts over this.
MelVic
For 1.3, you will need to duplicate all three movies and link separately.
M1 M2 M3, copies M10 M20 M30
playall
menu->M1->M2->M3
episodes
menu ->M10
->M20
->M30
In DVDLAB Pro this is a very easy task to do.
playall -> playlist object
episodes -> link to each movie.
Brian
Originally Posted by MelVic-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
You don't need to duplicate the files which will double the amount of space required on the disc. Check the link I posted, you can do it by editing the ifo file in ifoedit.
Thanks Craig, im editing now, its a little hard to follow as mine differ's alot from the example, lol but im getting there, Thank You
MelVic -
Let me know how you get on, as I have never used this method myself, but will be doing pretty soon.
Hi craig, ive stripped my menu to the bone, trying to make mine identical to the example i got from you. ive followed it, but im puzzled at one point, in the diagram showing the menus and movies, you can see the dummy menu, ive put a link from the Play All button to this dummy play all menu, now i have one blue link from the root menu to play all menu. looking at the example there's 2 links one going too the play all and one going from the play all, now im confused ive edited the ifo to extactly the examples, but all i get is a flash when i press the play all button,
60gb Avi file - To DVD - Puzzled
By andrewmpalmer2003 in forum Video ConversionReplies: 6Last Post: 1st Apr 2010, 09:56 -
DivX v/s Xvid trial and error now puzzled, read toward end
By adiktlost in forum Newbie / General discussionsReplies: 7Last Post: 12th Jan 2009, 21:37 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 08:53 -
dvd-lab...no audio
By sylvester243 in forum Authoring (DVD)Replies: 2Last Post: 11th Jan 2008, 03:00 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 08:52
