which is better in encoding nero6 or tmpgenc with NORMAL motion search precision? which has the better quality output? i only plan to use NORMAL motion search precision coz HIGH is so slow and i need to finish my projects ASAP...
ill convert my wmv, mpg, avi files to vcd format using TMPGEnc first then burn them using Nero 6.
but if Nero 6 is better in encoding than TMPGEnc with Normal motion search precision then ill directly encode and burn using Nero6
hacking the Net using typewriter :D
Nero is one of the best burning softwares - but their encoding options are usually lackinbg - since these are only supplementary to the burning function. always use designated programs for designated tasks - they wrok better, and quite often faster. in this case - use tmpeg.
With all due respect... and there is respect... -
Its Nero Burning Rom and not Nero Encoding Rom. Hope that answers your question.
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 23:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 09:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 08:15 -
TMPGEnc Authoring Works 4 Encoding
By mabrandt in forum Authoring (DVD)Replies: 3Last Post: 28th Oct 2009, 11:45 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 23:23
