Since upgrading from Windows 98se to XP, I can no longer burn or copy a cd unless i am burning a VIDEO CD.
I have reinstalled Nero and I keep getting the "AUDIO EXTRACTION NOT SUPPORTED" Error.
I also have windows media player 9.
I have deleted the CDROM.CFG file and i continue to get the error.
Any help would be appreciated?
Kyri
First...You never should have upgraded. You should have reformatted and done a clean install of XP.
Next...I'm running XP Pro and have always used Nero 5.5x on this OS with No Problems.
I would try uninstalling Nero and cleaning your registry of all Ahead (Nero) entries and reinstall. If that doesn’t work, blow away your hard drive and do a clean install of XP.
Your not clear on what's up with WMP 9, so I'm not sure what you want.
Wish I had better news for you.Geronimo -
Clean install
Thanks Guys. When you say clean install ....do you guys mean i should do a clean install of XP or Nero?.
I can burn cd's using XP burning wizard & wmp9 but cannot use Nero apart from making a video CD.
wHY. -
Uninstall, get the Nero cleanup tool (Nero site) run it, reboot and reinstall.
I'd do a clean install of xp... upgrading usually gives bad results and leaves an abundance of crap behind... just backup all your needed files - format your main drive and install XP clean... then install nero and it should be a very easy path from there...
i'd also recommend you to get a newer version of nero - i like to keep myself up to date.
With all due respect... and there is respect... -
http://duxcw.com/faq/win/xp/clean.htm
a guide on doing clean install of upgrading to XP.
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 11:31 -
Cooling Solutions - *Solved & updated* Problems w/overheating & idle temps
By Noahtuck in forum ComputerReplies: 21Last Post: 28th Jul 2010, 22:30 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
nero 8 & dvd shrink
By jerbevpicasso in forum Newbie / General discussionsReplies: 17Last Post: 24th Oct 2007, 22:36
