I have demuxed an Mpeg1 file so I can change the audio to a different format only once the file is demuxed the audio and video are a different length (ie. 42:47 for the video and 42:44 for the audio). Remuxing the video and audio back to a Mpeg1 file puts the audio and video out of sync at the end of the video. I assume this is because of the difference in lengths of the video and audio.
Is there a way to stretch the audio back to make it the same length as the video to solve my syncing issues. Some of the Mpeg1 files I demux don't have this problem so I assume it isn't the demuxing software.
start with your audio track in a quicktime window.
then open the video in another quicktime window.
select all, then copy.
go to audio window, select "add scaled" & see if that works.
if not, try adding scaled audio to video window.
dk -
Thanks for the quicktime add scaled trick. I first had to convert the mp2 audio file to a wav file first so quicktime would allow me to copy the audio and past it scaled over top of the m1v file.
To convert to a wav file I had to use Mpeg2works. Unfortunately ffmpeg didn't seem to have a mp2 audio to wav converter.
AVIDEMUX syncing problems
By dan_man555 in forum Video ConversionReplies: 15Last Post: 20th Dec 2012, 17:01 -
Syncing manually.......
By GwnLee in forum SubtitleReplies: 3Last Post: 14th Sep 2011, 09:46 -
Syncing 3 Files at once
By Shaunk in forum Newbie / General discussionsReplies: 0Last Post: 16th Jan 2011, 06:59 -
"syncing" problems
By agent222 in forum Authoring (DVD)Replies: 3Last Post: 1st Jun 2010, 22:27 -
rmvb to avi, sound syncing problems, any tips or tricks
By dudeboy in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 08:19
