What I meant was the title of your post is misleading. Regardless, I think you mean your first thread on July 9th, your third is something elseMy third thread on July 9 explained it. I was peeping thru a hole inside an ivory tower, after seeing so many valuable information and different valid opinions.
Results 61 to 83 of 83
Pioneer stopped production a long time ago. CMC I believe makes most of TDK's DVD-R media now although with TDK MID code. TDK has also started own production of DVD+R media recently. Maxell makes a few DVD+Rs too, at least CDRInfo has used them in reviews and media with Maxell MID code is in Philips list of approved media.Originally Posted by Bodysurf
Call it whatever you want, it's working at that's what's important. Whether DVD-R or DVD+R with DVD-ROM book type is more compatible can be discussed in eternity and it's more or less impossible to prove anything as the difference is so small that you would need to test thousands of DVD players to show anything for certain. I have however seen more references to DVD+R with DVD-ROM book type working when DVD-R doesn't than the opposite.Originally Posted by Bodysurf
Then you have a Pioneer, certainly the most optimized burner for DVD-R. I doubt that for example TY -R media is generally better than the +R if you compare the burn quality on different burners.Originally Posted by Bodysurf
And then by Godwin's rule the thread should be closedOriginally Posted by lordsmurf
"As an online discussion grows longer, the probability of a comparison involving Nazis or Hitler approaches one. There is a tradition in many Usenet newsgroups that once such a comparison is made in a thread the thread is over, and whoever mentioned the Nazis has automatically lost whatever argument was in progress." http://encyclopedia.thefreedictionary.com/Godwin's%20rule -
Well, times have changed since Godwin made up his 'rule'. Who cares about Nazis if theyre nothing more or less than, say, Vikings, or Holy Inquisition (or was it Saint Inquisition?) - just a bunch of bad dudes mentioned in a history. Not this generation anyway.
That DVD+R with DVD-ROM booksetting *again* used as argument here? Holy crap!
If standalone player's *laser* cant read DVD+R, it still won't read it even if you set its book-type to DVD-ROM or CDDA or whatever you want. Example: old Apex AD-600 (or 500) model.
If your standalone player can't read DVD+R as "DVD+R", but it will read it as a fake "DVD-ROM" then you just have a shitty firmware on this player, nothing more.
Hardware deficiency of one player cant be solved by simple book type setting LOL! -
Okay, poor wording.Originally Posted by tompika
Let me try again. The DVD-R booktype, being made by the DVD Forum, is already as close to the DVD-ROM booktype as it can get. Changing it to DVD-ROM should not serve any other real function. I can only assume this is because the Forum has all the info they need.
Now, DVD+R, being rogue and all, may not have that info. DVD+R booktype is not as close, at least judging by compatibility issues, ESPECIALLY under the reasoning that DVD-ROM booktype fixed some issues (although altering booktype still does NOT make the DVD+R format more compatible than the DVD-R format, but it closes up a bit of the gap).Want my help? Ask here! (not via PM!)
Uhm if the player's "laser" can't read any burned DVD+R the chances for it to read a DVD-R is slim to none. A DVD+R and DVD-R have the same general physical properties when burnt, there are much bigger differences between dyes of different manufacturers within one format than between one manufacturers +R and -R dye.Originally Posted by DereX888
BTW check the DVD player section and you'll see reports that confirms that the AD-500/600 plays DVD+R with DVD-ROM book type.
lordsmurf: Sorry but from your explanations I take it you still have no clue what book type really is... "Being close to DVD-ROM book type"
EOD for me. -
Then explain booktype better.Originally Posted by -jsl-Want my help? Ask here! (not via PM!)
More like "I see your 10, and raise you 20"
Am I the only one who doesn't get this?Originally Posted by lordsmurfYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Again, if you can do beter.... THEN DO IT..
Just in case one does not find the glossary.
Booktype is an info in the lead-in section on every DVD disc that tells the player which kind of media is loaded so it can correctly choose the reading strategy.
DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL
Pressed medias have DVD-ROM booktype.
DVD-R's have DVD-R booktype, DVD-RW discs have DVD-RW booktype pre-written on them
PS: I don't give a **** which company wins I burn both kind
This sentence just doesn't make any senseThe DVD-R booktype, being made by the DVD Forum, is already as close to the DVD-ROM booktype as it can get.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
NuTec and Nic Wilson (DVDInfoPRO) invented a kinda bitsetting for DVD-R/W by burning one more session on them.
It does not have much benefit but I seem to recall an Xbox owner who couldn't play DVD-R before.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Looking at the definition of Bitsetting in the Glossary, I only see mention of DVD-ROM, DVD+R and DVD+RW booktypes.
https://www.videohelp.com/glossary?B#BitSetting
I'd hazard a guess that DVD-R/RW wouldn't fit the DVD+R or DVD+RW booktype. With only one option left (unless the mods need to update the Glossary with more information for a complete definition), what is there to change on a DVD-R/RW?Nothing can stop me now, 'cause I don't care anymore. -
DVDInfo PRO allows any booktype to be burned.Originally Posted by ViRaL1
I have burned several DVD+R with DVD-R and DVD-RW booktype and DVD+RW with DVD-R and DVD-RW booktype and found only one notebook DVD ROM combo that refused to play DVD+RW burned as DVD-RYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I think it's really immaterial. Both formats have been around for long enough and are likely here to stay, unless they screw up in the future or are both replaced by an even better format such as TGPO +- or the like.
There are many ways to measure success. You just have to find your own yardstick. -
I don't doubt that it can be done. I understand that by bitsetting a "+" you stand to gain compatibility with players that only recognize DVD-ROM. What I'm not understanding is what you gain by being able to set the book type on "-".
The reading strategy of the DVD-R and DVD-ROM are close relatives. This is possibly why the compatibility rating of DVD-R is so high.Originally Posted by tompika
In contrast, the DVD+R booktype is so far different than DVD-ROM that changing it to something more similar allows the player to work better with the disc.
I don't see why you say this does not make sense.
Maybe this is not the way it is, but this is how it was explained to me by some firmware dabblers, and it makes very logical sense.Want my help? Ask here! (not via PM!)
Maybe for compatibiltiy of some "-" disc will not play inside some XBOX DVD-ROM drives. I am guessing, maybe Tompika would supplement.Originally Posted by ViRaL1Sam Ontario
With XBOX, you must pay attention to the file structure when burning. I have one. I know. It can be a real b@#$%Originally Posted by Sam OntarioWant my help? Ask here! (not via PM!)
Just one more comment from me in this thread and I'll try to explain why it doesn't make sense:Originally Posted by lordsmurf
The first byte of the physical format information (the data that describes the basic physical properties of the disc) specifies the version number and disc category. The latter is also known as the book type. Example:
DVD-ROM disc category: 0000
DVD-R disc category: 0010
DVD-RW disc category: 0011
DVD+R disc category: 1010
DVD+RW disc category: 1001
So “bitsetting” a DVD+R to DVD-ROM means that instead of setting the disc category to 1010 you set all four bits to zeros. And saying that DVD-R book type is “close” to DVD-ROM book type is like saying a binary 1 is close to a binary 0, simply stupid.
So why does disc category/book type affect the compatibility then?
Well some “stupid” DVD players are programmed to only play certain disc categories. I.e. insert a disc with a disc category that it’s not programmed to play and it will refuse to play it without even trying. As DVD-R is an older format than DVD+R more old DVD players will naturally recognize the DVD-R disc category than the DVD+R disc category as they're programmed to do so. Some manufacturers have also refused to make their DVD players recognize the DVD+R format even long after the format’s introduction (e.g. Panasonic, Toshiba…) because of the so called format war. Setting the disc category/book type to DVD-ROM instead of DVD+R will in most cases fool these players to accept the disc.
Because there are a few players that only recognize the DVD-ROM book type and no other book types there are even some players that accept a DVD+R with DVD-ROM book type but not a DVD-R. But for various reasons the opposite can also be true for a few players. In both cases it affects very few players though and therefore the difference in compatibility between DVD-R and DVD+R with DVD-ROM book type is negligible and arguing about what’s more compatible will lead nowhere as no one can really prove anything. The quality of the disc, the used burner or even the software is more important for the compatibility than the format here imho. -
Well said JSL,
I see there are still those around who haven't tried "bit-setting" +R discs, despite the majority of burners now supporting this feature (hacked firmware or otherwise). It's been a long hard road convincing many of the undeniable benefit of the DVD-Rom book type. Rather than try burning one the shutters come up and silly arguments take place.
It will be interesting in the current situation of double-layer +R media and the DVD-Rom book being used as a widespread fix for players. After all 12 months ago no player could know of a DVD+R DL book-type. Simply bit-set to DVD-Rom and away it goes.
What pray tell can be done for DVD-R DL and a pre-written lead-in of that book-type. Me thinks Pio are in for a re-write of their much vaunted standards if and when such media materialises.
Regards
Studebarc.
16x DVD+R media to arrive in Sept....?
http://home.businesswire.com/portal/site/google/index.jsp?ndmViewId=news_view&newsId=2...78&newsLang=en
Filming Race cars
By bfleming76 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 24th Jun 2011, 13:33 -
Panasonic GS-250 taped race has area of no picture but sound
By helper in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jul 2010, 05:32 -
help! corrupt h264 video from Sunday's incar race using a GOPRO HD
By johngeorge in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 09:34 -
Backing Up Death Race Blu-Ray
By mr.adventure in forum Blu-ray RippingReplies: 26Last Post: 14th Jan 2009, 11:18 -
Is the graphics card arms race impossible to keep up with?
By yoda313 in forum PollsReplies: 19Last Post: 15th Sep 2008, 02:58
