Hi Guys. Wondering if any of you R200 owners have printed any DVDs using the ProDisc inkjet printable brand. I have and am having a difficult time getting the color to come out right. It is either too dark or too light regardless of what I set the software settings on. If anyone has had good luck with theirs would you please share your print settings with me. Thank you for much for your help.
Results 1 to 13 of 13
Thank You,
GolfNut -
https://www.videohelp.com/forum/viewtopic.php?t=202296
https://www.videohelp.com/forum/viewtopic.php?t=220449
All the info you need in these 2 threads
I am curious about this comment though
Originally Posted by golfnut -
I have printed on about 30 ProDisc IPA with my Epson R200 and they all came out perfectly!
Did you do print-head clean up, aligment...?
Are your ink-cartridges original or refill ones ?
I don't have the printer manual with me right now but it should have a trouble-shooting section in there.
World -
World thank you for the reply. Yes heads are clean, did an alignment, cartridges are the original Epson cartridges which came with printer and are two thirds full.
Thank You,
GolfNut -
I've printed a bunch of ProDisc on the Epson R200 and really haven't had much problems. The settings I used are default print colour correction, but I set the colour management in the printer driver to ICM instead of the default which is Epson Vivid. If you're still not getting the colours to come out correctly I'd check the discs and make sure you have the inkjet printable ones and not the thermal printable ones, if that doesn't work maybe your monitor's not calibrated correctly hence what you see on the screen isn't what comes out of the printer.
-LeeBear -
I'm just curious about your comment LeeBear, what ICM file do you use? Just recently I've started experienceing too much blue in my disc prints, I wonder if this will help.
check out another thread that's around - it seems to be a problem when you're low on black ink... it starts using more blue...Just recently I've started experienceing too much blue in my disc prints, I wonder if this will help.With all due respect... and there is respect...
LeeBear thanks for the tip, I will give that a try. Have a great day.
Thank You,
GolfNut -
The printer is using the standard default colour profile of the printer which is EE251__1, but for ICM to work properly your monitor also have to be calibrated with a proper profile. There's various programs you can use to create the monitor profile. Just don't use any of the default profiles (ie. sRGB) since they're hardly ever correct and even if the monitor did come with colour profiles in it's drivers it usually still needs to be tweaked cause everyone's lighting conditions are different. You can see (and add) what profile your monitor is using by going into display properties.Originally Posted by james_stewart
-LeeBear -
LeeBear thanks for the heads up, hope this simple mind can do all of this.
Thank You,
GolfNut -
LeeBear can you tell me the names of these programs when you say "various programs", thanks again for your help.
Thank You,
GolfNut -
http://desktoppub.about.com/cs/colorcalibration/a/cal_monitor.htmOriginally Posted by golfnut
just one link of many from
http://www.google.com/search?sourceid=navclient&ie=UTF-8&oe=UTF-8&q=how+to+calibrate+your+monitor
google, impowering the people
Epson R200, new cheaper disk printer?
By The village idiot in forum MediaReplies: 309Last Post: 26th Mar 2012, 09:56 -
Win7 drivers for the Epson R200?
By MrSpeed in forum MediaReplies: 0Last Post: 27th Apr 2010, 04:50 -
Epson R200 printer and DVD art
By dymx in forum ComputerReplies: 4Last Post: 8th Jul 2008, 11:57 -
Growing very tired of Epson's R200 - R220
By stiltman in forum MediaReplies: 25Last Post: 25th Jun 2008, 23:58 -
Installed R260 Epson, and the print CD keeps recognizing my old R200
By faramith in forum MediaReplies: 11Last Post: 2nd Dec 2007, 18:29
