I have used many, but prefer Adobe Premiere 6.5. Ulead VideoStudio 6 worked great also, but only captured in Type1 DV which gives an issue if you ever use Virtualdub to edit. I'm currently testing out Mainconcept, but nothing in depth as of yet. I'm looking at mainconcept for it's DV to Mpeg2 on the fly capture ability to Half D1 for videos that aren't as important to me.What software do you use to capture the video pass thru?
Do you have to remove the tape?
Do you have to set anything special up on the camera to use the passthru to the Fwire port?
Anything else you learned during your experiments that may help?
Yes I have to remove the tape or else every program on the computer tries to read the tape instead of the passthrough video.
I have a Sony DCR-PC101, I think the only thing I had to set up was to enable the DV out on the camera and enable Video in for the passthrough.
I have tried WinDV and DVIO for capture, but when I capture long clips >45minutes, the audio goes out of sync for me. Think it's something with the Sony cam, there have been posts about this, just don't remember the specifics.
Good luck
Edited added quote and some other stuff about DVIO and WINDV.
Results 31 to 33 of 33
Outstanding and Thanks!
I use the MainConcepts MPEG Capture product now and it works rather well for DV --> MPEG captures... I will try and see if it works via this passthru as well.
Tx -
FYI...
Pass through .AVI vs miniDV .AVI out put.
I've done it quite often and I use my GL2 pass through to transfer from Hi8 and VHS using Pinnacle 8. I notice that there's a large black line on the bottom of the footage. If it is a true miniDV tape, it is fine. I've heard people mention this issue on this board a few times, but I forgot what the resolution was or it never had. If I capture it via Hauppuage (spelling?), I didn't have that problem, but the quality is not as good as the pass through avi and encode it with TMPGENC.
vcdlover
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
