Well out of intrest, are the +r discs any more compatable than the +RW discs?.
It's just that as I'm about to buy my first recoder (still no advice on the model?) I've noticed that most seem to record on +rw discs instead of +r discs. Is there any real reason behind this rather than the ability to re-use the disc?. I'd have thought that write once media would be more compatable with dvd players than re-writable ones. This is something I realised from my Pioneer A05 dvd burner ehere the -rw ones did'nt work to well in my players.
My other concerns is that both my current dvd players are older models & I'm therefor concerned that weather or not I buy +rw or mainly +r discs they may not work as well as the - format, thus the reason why I was originally looking at buying a - format compatable recorder.
I guess\gather some members use the +rw discs to afterwards rip the disc to pc & then re-auther it with a decent menu system to either a dvd-r or dvd+r.
So are there any real compatability issues I really need to think about when deciding on +r or +rw discs or what media I should use?.
I know from my pc burner that any Ritek die -r discs are best so what should I be looking at when buying the + format discs for compatibility?.
Dave9946
That's the only reason I use them....well that and the fact that Philips DVD Recorders are +R machines and that is what I own...Originally Posted by Tubol
I use BenQ and Philips DVD+RW's for transfering video between the Philips Recorder and my LG4040B burner in my computer....then I normally use Ritek -R's to burn permanently.
Common Codecs and xVid / DivX compatability
By anonymous_whatever in forum Newbie / General discussionsReplies: 25Last Post: 20th Feb 2012, 18:53 -
Sony WEGA KE-42M1 Compatability with Panasonic Blue Ray
By Worlcup in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Dec 2011, 00:14 -
Video Playback, File Compatability
By TomFriedmann in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2011, 09:14 -
Sony Z7 compatability
By 392 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 4th Nov 2009, 23:06 -
Compatability of DVD+R DL media with LG LDA-831??
By jamiemark in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Mar 2008, 11:07
