Does anyone know how to make subtitle files generated by an autogknot conversion to be usable by xbox mediacenter?? or how to make some that are!?! I know xbmc does not support compressed subs.
Hello,
You may want to try xbox-scene.com. They have a ton of xbox hack info. Good luck.
Um, do you insist on using AutoGK? Or could you use GK? 'Cuz I'm willing to experiment a little to help you out, but I can't use AutoGK
. My 'Box is my only DVD drive. IF you can use GK, I'll try to figure out a way to do it for you. *Crosses fingers*
"Gratuitous complexity is akin to chaos" - True Vox
AVer MediaCenter saves video at 50fps when there ment to be 25fps
By jamespoo in forum DVB / IPTVReplies: 1Last Post: 17th Jun 2011, 02:39 -
Looking for testers for MediaCenter Jukebox free plugin
By htensfeld in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Dec 2009, 17:33 -
Laptop as mediacenter
By realrisk2 in forum Newbie / General discussionsReplies: 25Last Post: 6th Oct 2009, 15:32 -
adding subtitles to xbox 360 compatible 5.1 wmv file
By TF2MarkP in forum Newbie / General discussionsReplies: 3Last Post: 30th Aug 2009, 19:16 -
Elisa mediacenter and DVD support
By Robert1974 in forum Media Center PC / MediaCentersReplies: 0Last Post: 28th Aug 2008, 13:50
