I'm making a dvd from an avi file but after it's burn there's no sound or sort of buzzing sound.
I use virtualdb to edit the avi, then use winavi to convert into .vob files which I then use Nerovision Express to burn it with a simple menu.
When i play the vob files through Cyberlink dvd software on my pc its all fine, the sound is perfectly fine like it is on the original .avi file. Is the fault with my nerovision express ?
burn with another tool, https://www.videohelp.com/guides.php?howtoselect=3;25#3;25 . nerovision express may reencode again.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
