I am trying to back up a copy of a dvd that has an error at 100%. my friend did it on the fly but I only have 1 drawer is there another way I can do it? I have tried to load it into nero burning rom, shrink, decryter and record now ...all did not want to take it in. I have heard that alcohol will do the trick...anyone had any luck with this type of problem???
If by drawer you mean drive, you can select the Image Recorder as your buring device in Nero and it will create an image of the DVD on your Hard Drive.
I will almost put money on that there is a fingerprint smudge right on the outer edge of the disc. Wipe the very outer edge with a soft cloth and see how you go.If in doubt, Google it. -
have you tried a dvd rescue app such as dvd-x-rescue?
anyway - you can make an image of the disc (as said above or via other apps for image making) and then load the image with alcohol120%.
after doing that you can copy on the fly with nero because he thinks that you actually do have another drive (the virtual one made by alcohol).With all due respect... and there is respect...
de-interlacing on the fly with FFDshow
By davexnet in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2010, 21:59 -
drawer won't shut on Medion DVD player??
By wundahoss in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Sep 2010, 03:15 -
Question About on the Fly Editing
By guarddog in forum EditingReplies: 1Last Post: 29th Jan 2010, 04:07 -
DS Filter for on-the-fly TS repair?
By HDVidiot in forum DVB / IPTVReplies: 2Last Post: 10th Jan 2008, 14:57 -
Urgent Help! - Panasonic Mini DV NV GS series tape drawer problem
By kwame in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th May 2007, 14:28
