Dvdshrink worked great untill I had to reformat my hardrive(Not because of this program )
And now when I try to duplicate a dvd it gets stuck at "burning 0% writing lead in ". I cannot end task or close the program, so I'm going to reinstall it and nero and see what happens. I also have installed the aspi layers and increased the page file size but, still burning stuck on 0% can anyone help me out ?
Try to burn from DVD folders or from image and see if that helps. I would reinstall NERO.
Tried that too and it did not work but, I reinstalled dvdshrink and it works fine now thank you
/////////////////////////////////////////////////////////// Put your finger here! ----------> x x //////////////////////////////////////////////////////////////// Ha Ha now you have to clean your screen
IMGBurn no lead-in with +R discs
By samijubal in forum DVD & Blu-ray WritersReplies: 21Last Post: 17th Sep 2010, 15:50 -
Toast 9 gets stuck forever at writing DVD lead-out
By soundchaser in forum MacReplies: 11Last Post: 26th Mar 2009, 08:17 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
jvc gz mg505 av lead
By merray in forum Newbie / General discussionsReplies: 0Last Post: 20th Dec 2008, 05:08 -
How do i change the default writing speed in Nero when using DVDshrink?
By wallacem4141 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2007, 06:15
