Hi there,
I have compressed Alien 1 & 2 onto one DVD and I want to include audio clips for the main menus.
Where can I download clips that are AC3 or PCM compatible. Otherwise, what program could I use to extract a section of audio from the main movie file, and then use that instead.
Thx.
I guess a simple way would be to use DVDShrink in reauthor mode and crop the parts you want that have the audio. I'm not 100% sure if you can have audio preview in reauthor though
but maybe you don't need it as its obvious where you need to crop
you can then use VOBedit to split the VOB's afterwards into audio/video
how to enhance sound qaulity of dvd clips from security cameras
By sydneynewbie in forum Newbie / General discussionsReplies: 15Last Post: 4th Apr 2009, 05:36 -
Windows Movie Maker - Why is there no sound after video clips captured?
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Dec 2008, 09:45 -
iMovie HD 6.03 Project: Equalizing sound on movie clips?
By iMacMan in forum MacReplies: 2Last Post: 30th Jan 2008, 03:53 -
Motion Menu with custom clips?
By chaosnovaxz in forum Authoring (DVD)Replies: 16Last Post: 14th Jan 2008, 10:49 -
Nomalizing sound of many video clips
By davidra in forum AudioReplies: 4Last Post: 6th Sep 2007, 05:13
