hey,
just wondering what version of tmpgenc do you people use, and which divx codec should i install?
what settings do you have for environmental in tmpgenc esspecially where you can make the priority for those ones higher or lower.
also, what is the first thing you guys do when you get a movie that is slightly out of sync while using tmpgenc. btw, i usually rip the audio with virtualdub (full processing mode) before i encode.
any other process you use to encode?
thanks a lot guys.
thing is,
i gotta new comp last year (athlon xp 2500, 512 ram, 256VC) and got the latest divx codec (5.11) and tmpgenc Pro, and am just not making normal vcd's like i used to. I had a celeron 266mhz 128 ram machine with divx 3.1 and the old tmpgenc and used to make vcds like crazy. i have over a 150 from that old machine.
i still see what the frame rate is and encode according to it, use virtual dub, etc...
what is the best divx codec and tmpgenc to use in order to get regular divx and xvid movies into properly working vcds?
ps: i have a xvid codec and burn using nero, never had a problem.
thanks a lot
Simple VHS Capture Questions
By mostly_useless in forum Capturing and VCRReplies: 4Last Post: 29th Dec 2011, 17:00 -
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 11:47 -
New to video making. I have a few simple (I hope) questions.
By BornRuffian in forum Newbie / General discussionsReplies: 1Last Post: 27th Apr 2009, 01:01 -
Some simple questions about Dreambox and HTPC
By Talayero in forum DVB / IPTVReplies: 0Last Post: 8th Apr 2009, 12:44 -
VBR encoding problems with TMPGEnc 4XP
By maccool111 in forum Video ConversionReplies: 2Last Post: 8th Jun 2007, 05:42
