Hey, I'm new to this program but have spent a great deal of time learning the basics. Now I am a bit stuck and not sure what I am doing wrong. Here is my terminal info:
Encoding started on Sat Jul 3 20:19:39 PDT 2004
-f 5 -b 2661 -q 6 -B 260 -V 230 -a 2
-F 1
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
Using GNU internationalization
Original domain: messages
Original dirname: /usr/local/share/locale
Current domain: mplayer
Current dirname: /usr/local/share/locale
MPlayer dev-CVS-030316-14:10-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
AltiVec found
: No such file or directory
Reading config file /usr/local/etc/mplayer/mplayer.confReading config file /Users/mikey/.mplayer/config
can't open '/Users/mikey/.mplayer/codecs.conf': No such file or directory
can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm' '-waveheader' '-v' '-osdlevel' '0' '/Users/mikey/Desktop/ogmtools/TheSevenGuys.avi' '-aid' '1' '-sid' '0' '-sub' '/Users/mikey/Desktop/ogmtools/TheSevenGuysSubtitles.srt'
get_path('font/font.desc') -> '/Users/mikey/.mplayer/font/font.desc'
font: can't open file: /Users/mikey/.mplayer/font/font.desc
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Unoptimized OnScreenDisplay
Using usleep() timing
Terminal type `unknown' is not defined.
get_path('input.conf') -> '/Users/mikey/.mplayer/input.conf'
Can't open input config file /Users/mikey/.mplayer/input.conf : No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
Falling back on default (hardcoded) input config
get_path('TheSevenSamurai.avi.conf') -> '/Users/mikey/.mplayer/TheSevenGuys.avi.conf'
Playing /Users/mikey/Desktop/ogmtools/TheSevenGuys.avi
Not an URL!
File size is 1283433604 bytes
AVI file format detected.
list_end=0xD4
======= AVI Header =======
us/frame: 41708 (fps=23.976)
max bytes/sec: 0
padding: 0
MainAVIHeader.dwFlags: (272) HAS_INDEX IS_INTERLEAVED
frames total: 297086 initial: 0
streams: 1
Suggested BufferSize: 0
Size: 640 x 480
list_end=0xD4
==> Found video stream: 0
======= STREAM Header =======
Type: sdiv FCC: 05XD (30355844)
Flags: 0
Priority: 0 Language: 0
InitialFrames: 0
Rate: 23976043/1000000 = 23.976
Start: 0 Len: 297086
Quality 0
Sample size: 0
found 'bih', 40 bytes of 40
======= VIDEO Format ======
biSize 40
biWidth 640
biHeight 480
biPlanes 1
biBitCount 24
biCompression 808802372='05XD'
biSizeImage 921600
Regenerating keyframe table for DIVX 4 video
list_end=0xF6
hdr=Software size=13
Software : ogmtools-1.1
Broken chunk? chunksize=1782 (id=KNUJ)
list_end=0x4C371C9C
Found movie at 0x800 - 0x4C371C9C
Reading INDEX block, 297086 chunks for 297086 frames (fpos=0x0)
AVI: invalid audio stream ID: 1 - ignoring (nosound)
AVI index offset: 0x0 (movi=0x800 idx0=0x800 idx1=0x1526)
Auto-selected AVI video ID = 0
AVI_NI: No audio stream found -> no sound.
AVI video size=1276221765 (297086) audio size=0 (0)
VIDEO: [05XD] 640x480 24bpp 23.98 fps 824.0 kbps (100.6 kbyte/s)
[V] filefmt:3 fourcc:0x30355844 size:640x480 fps:23.98 ftime:=0.0417
Clip info:
Software: ogmtools-1.1
SUB: Detected subtitle file format: subviewer
SUB: Read 1330 subtitles.
vo_yuv4mpeg: Using (default) progressive frame mode
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
INFO: libavcodec init OK!
Selected video codec: [ffodivx] vfm:ffmpeg (FFmpeg MPEG-4)
Audio: no sound
Freeing 0 unused audio chunks
Starting playback...
This file was encoded with DivX503 Build1031
[ffmpeg] aspect_ratio: 1.333333
VDec: vo config request - 640 x 480 (preferred csp: Planar YV12)
Trying filter chain: vo
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
VO Config (640x480->640x480,flags=0,'MPlayer',0x32315659)
VO: [yuv4mpeg] 640x480 => 640x480 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools (to "stream.yuv")
VO: Author: Robert Kesterson <robertk@robertk.com>
*** [vo] Allocating (slices) mp_image_t, 640x480x12bpp YUV planar, 460800 bytes
INFO: [yuvscaler] SVCD output format requested in NTSC norm
INFO: [yuvscaler] input: frame size: 640x480 pixels (460800 bytes)
INFO: [yuvscaler] input: frame rate: 23976043/1000000 fps (~23.976043)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: ?
INFO: [yuvscaler] from 640x480, take 640x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 640x480, 640x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
ler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 640x480 pixels (460800 bytes)
INFO: [yuvscaler] output: frame rate: 23976043/1000000 fps (~23.976043)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: ?
INFO: [mpeg2enc] Selecting SVCD output profile
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/mikey/Desktop/ogmtools/TheSevenGuysSVCD.mpv
INFO: [mpeg2enc] Horizontal size: 640 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
INFO: [mpeg2enc] Bitrate: 2661 KBit/s
INFO: [mpeg2enc] Quality factor: 6 (Quantisation = 6) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 260 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
INFO: [mpeg2enc] Progressive format frames = 0
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
0 0 0%
= 67054.3
0 0 0%
2% 0.0% 0 0 0%
B quant=6.00 total act= 74130.9
act= 74477.4
0 0 0%
t (15 frames)
6% 0.0% 0 0 0%
79989.6
345
0 0 0%
rame number 437
8% 0.0% 0 0 0%
e end 423 P quant=9.37 total act= 88337.9
448
umber 6364
11% 365% 0.0% 0 0 0%
ame number 6411
0 0%
me end 6395 I quant=17.98 total act=1082563.1
tal act=1082929.3
0.0% 0 0 0%
otal act=1083459.6
mber 6434
ames)
umber 13272
ame number 13283
end 13261 B quant=6.00 total act=1531627.0
e end 13268 P quant=6.00 total act=1531978.6
19133
(14 frames)
534 P quant=6.00 total act=4067743.1
2541 B quant=6.00 total act=4068073.0
2565
6.13 total act=4068559.6
=6.00 total act=4068925.1
umber 52575
end 52693 I quant=6.00 total act=4079760.7
B quant=8.03 total act=7032323.3
3 B quant=8.00 total act=7032536.8
97496
ame number 97509
3% 359% 0.0% 0 0 0%
uant=10.05 total act=7037433.5
e number 97608
37930.1
t=7038177.0
.2
header damaged
vop not coded
Error while decoding frame!
0 0%
mber 262775
0% 0 0 0%
0 total act=19160317.3
759 B quant=6.00 total act=19160807.6
13% 366% 0.0% 0 0 0%
0 0%
me end 264348 B quant=6.00 total act=19289154.9
0% 0 0 0%
ds_fill_buffer: EOF reached (stream: video)
EOF code: 1
uninit video: ffmpeg
DEMUXER: freeing demuxer at 0xee3000
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 297087!
Exiting... (End of file)
INFO: [mpeg2enc] Guesstimated final muxed size = 3974353217
wait, encoding to mp2 audio with mp2enc...
/Applications/ffmpegX.app//Contents/Resources/mencvcdX: audiodump.wav: No such file or directory
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/mikey/Desktop/ogmtools/TheSevenGuysSVCD.mpv looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /Users/mikey/Desktop/ogmtools/TheSevenGuysSVCD.mpa for reading.
Just wondering if someone is able to push me in the right direction.
Thanx.
Apparently the sound track is not found. Try to disable the "Decode with mplayer" checkbox.
Thanx for the quick response Major. Much appreciated.
Anywho, I tried encoding with quicktome instead of mencoder and still no audio. Here is the info:
Encoding started on Thu Jul 8 23:40:32 PDT 2004
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=640x480, frame rate=24000:1001 fps)!!
INFO: [yuvscaler] input: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] output: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] SVCD standard settings selected
INFO: [mpeg2enc] Assuming norm NTSC
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/mikey/Desktop/ogmtools/TheSevenGuys.m2v
INFO: [mpeg2enc] Bitrate: 2500 KBit/s
INFO: [mpeg2enc] Assuming non-video stream of 230 Kbps
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Guesstimated final muxed size = 3712041786
error: movie contains no audio tracks!
If it helps, the file was originally an ogm. I demuxed it to avi and ogg. then ogg to mp3 to mp2. I'm trying to connect the avi and mp2 in ffmpegx. I've been putting the audio on track 0. Should I be putting in on track 1 or is there something else wrong with the way I converted my ogg sound files?
You could try again (with "decode with mplayer" enabled) directly on the source .ogm file.
Hey Major. Thanx again for helping me. I tried ffmpegx directly on the ogm file and still received a similar error to the first attempt, here is the info:
Encoding started on Thu Jul 15 05:05:54 PDT 2004
-f 5 -b 2500 -q 6 -B 260 -V 230 -a 2
-F 1
AltiVec found
Reading /Users/mikey/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm' '-waveheader' '-v' '-osdlevel' '0' '/Users/mikey/Desktop/ogmtools/TheSevenDudes.ogm' '-aid' '0' '-sid' '0'
get_path('TheSevenDudes.ogm.conf') -> '/Users/mikey/.mplayer/TheSevenDudes.ogm.conf'
Playing /Users/mikey/Desktop/ogmtools/TheSevenDudes.ogm
Not an URL!
File size is 1551290935 bytes
Checking for YUV4MPEG2
DEMUXER: freeing demuxer at 0xee2b20
ASF_check: not ASF guid!
Checking for NuppelVideo
Checking for REAL
Checking for SMJPEG
Searching demuxer type for filename /Users/mikey/Desktop/ogmtools/TheSevenDudes.ogm ext: .ogm
Trying demuxer 18 based on filename extension
OGG stream 0 is video (new hdr)
biSize 40
biWidth 640
biHeight 480
biPlanes 1
biBitCount 24
biSizeImage 921600
==> Found audio stream: 1
OGG : stream 1 is vorbis
==> Found audio stream: 2
OGG : stream 2 is vorbis
OGG stream 3 is text
OGG demuxer : found 2 audio streams, 1 video stream and 1 text stream
OGG file format detected.
[V] filefmt:18 fourcc:0x30355844 size:640x480 fps:23.98 ftime:=0.0417
get_path('sub/') -> '/Users/mikey/.mplayer/sub/'
Audio: no sound
INFO: [yuvscaler] input: frame rate: 23976041/1000000 fps (~23.976041)
INFO: [yuvscaler] scale to 480x480, 480x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling ratio for width is 4 to 3
INFO: [yuvscaler] Specific downscaling routing number 1
INFO: [yuvscaler] output: frame size: 480x480 pixels (345600 bytes)
INFO: [yuvscaler] output: frame rate: 23976041/1000000 fps (~23.976041)
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/mikey/Desktop/ogmtools/TheSevenDudes/TheSevenDudes.mpv
INFO: [mpeg2enc] Horizontal size: 480 pel
me number 789
0 0 0%
end 836 B quant=6.00 total act=189568.8
3% 0.0% 0 0 0%
0 0 0%
t=6.00 total act=202563.9
3% 0.0% 0 0 0%
853.5
otal act=205131.1
act=213058.4
8% 430% 0.0% 0 0 0%
149
er 22159
9 B quant=18.00 total act=2278788.0
25634
25880
ber 39998
978 B quant=8.20 total act=3105089.5
d 39985 P quant=8.62 total act=3105633.3
uant=8.52 total act=3106290.3
4% 319% 0.0% 0 0 0%
quant=8.84 total act=3106615.3
total act=3112001.1
e end 76266 B quant=6.00 total act=5452419.6
342 P quant=6.00 total act=5458844.3
6349 B quant=6.00 total act=5459569.2
umber 76367
ame number 76377
OGG : Page out not synced, we skip some bytes
*Sorry, it repeats this line like 50 times and the original post would't fit
OGG : bad packet in stream 0
0% 0 0 0%
% 312% 0.0% 0 0 0%
217630
217608 P quant=6.04 total act=15792536.5
0% 0 0 0%
me number 217638
16838226.1
0% 0 0 0%
% 318% 0.0% 0 0 0%
805 P quant=6.00 total act=16839352.0
16887209.7
0% 0 0 0%
me end 234654 B quant=6.00 total act=17196495.0
r 249219
13% 320% 0.0% 0 0 0%
06096.3
l act=18344067.9
0 0%
uant=9.70 total act=18344600.4
0% 0 0 0%
13% 321% 0.0% 0 0 0%
0 total act=20801576.8
0 0%
544 B quant=7.78 total act=20802127.2
me number 286570
0% 0 0 0%
2
13% 322% 0.0% 0 0 0%
564 B quant=6.00 total act=20884530.7
=20887271.2
ber 287620
0 0%
87614 B quant=8.93 total act=20888201.1
0% 0 0 0%
me end 287623 B quant=9.46 total act=20888825.7
tal act=20889806.8
B quant=6.00 total act=20890058.5
4
20891888.2
7713
0 0%
al act=20892434.2
287703 P quant=6.27 total act=20892888.9
0% 0 0 0%
94107.1
P quant=6.00 total act=20894864.2
quant=6.00 total act=20972137.2
EOF code: 1
DEMUXER: freeing demuxer at 0xee3390
DEMUXER: freeing sh_video at 0xee8dc0
DEMUXER: freeing sh_audio at 0xee5c10
DEMUXER: freeing sh_audio at 0xee5cc0
INFO: [mpeg2enc] Guesstimated final muxed size = 3698749329
INFO: [mplex] File /Users/mikey/Desktop/ogmtools/TheSevenDudes/TheSevenDudes.mpv looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /Users/mikey/Desktop/ogmtools/TheSevenDudes/TheSevenDudes.mpa for reading.
It recognized the ogm file and identified the video file, two audio files and the text file. In mmpegx, under the "video" tab I opened the ogm and then chose the "save as" name. I selected the quick preset for svcd then changed the cd selection back to "80m mode-1" because this is the type of disk I want to eventually burn to (am I missing some step in the video tab like the proper # of mins or disks - I left the disk # as 1 although the ogm is over 2 hours). I left the audio tab alone then checked the subtitles box in "filters" - I'm pretty sure this would have to be done in a separate step anyway). Under the "options" tab I deselected "letterbox" leaving "Altivec" and "Bicubic" selected. I then selected "decode with mplayer". Under "tools" I deselected "author as svcd" because I will need to add subtitles and hopefully a second audio file from the ogm later. I believe this was the proper procedure in one of the tutorials. This leaves only "split in auto chunks" and "keep elementary streams" selected". Perhaps I have not selected the proper boxes in "tools" or "Video" tabs. Anywho thanx for all your help so far.
C.J.
video overlay, may have posted to wrog forum
By Richpress in forum Software PlayingReplies: 0Last Post: 10th May 2011, 22:28 -
oops, I've stumbled into the wrong forum
By MackemX in forum Off topicReplies: 8Last Post: 1st Nov 2007, 15:27 -
Whats Wrong With This Forum?
By gealto2 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Jun 2007, 18:11
