Hi, i'm really not too sure which forum to post this on, i guess this was the obvious choice !!
Anyway, i have a SVCD which i was wanting to put onto DVD. Instead of re-encoding i usually use DVD-Lab which allows me to put the SVCD onto DVD only having to re-encode the audio etc. However this SVCD has a frame rate of 23.97 and when i try to open it in DVD lab the messege appears :
"In order to be able to use 24fps movie you need to enable pulldown"
It then converts the video to 25fps, but then when i watch the SVCD the audio is completely out of sync. I know this is due to the different framerate of the video, but how do i overcome the sync problem?
Do i have to re-encode the audio??
I'm kinda lost here and any help would be greatly appreciated!!
yeah, re-encode the audio to 25 fps, thereby matching the frame rate of the video.
if you plan to play the disc on your dvd player, i hope it can play PAL (25 fps).
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 05:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 17:17 -
Delaycut question about 6 chan ac3 out of sync when 2 chan is in sync
By B2K24 in forum AudioReplies: 3Last Post: 27th Apr 2009, 17:10
