I finally got my system set up and have been buring with good results. I'm using DVD Shrink & Nero with my Sony DRU500A orig f/ware. Yes, it does take over 1hr from start to finish but everything works.
My question is: Should I upgrade the firmware and hope or can I easily flash back if I encounter problems. I am currently using 2x media which is hard to come by.
Look forward to comments.
later...
Like Pete, I always use the latest firmware. This is the just a rule for me, be it drivers, or patches. If there is an update, that means a problem has been fixed.Originally Posted by oceanview
Anyway, I doubt you should encounter any trouble with new firmware. However, new firmware, at least for my burner DISABLED DMA. Because of that, DVDRs took twice the time and came out bad. Don't get alarmed. Just re-enable it if that comes up.
Handbrake Should i leave it on?
By JackDanielZ in forum Video ConversionReplies: 19Last Post: 18th Sep 2012, 10:13 -
LCD HDTV, leave it on all the time?
By moviegeek71 in forum DVB / IPTVReplies: 3Last Post: 11th Jun 2008, 20:34 -
How long should I leave my laptop on without killing it?
By moviebuff2 in forum ComputerReplies: 3Last Post: 18th Jan 2008, 11:20 -
Do you leave your computer on all the time?
By yoda313 in forum PollsReplies: 43Last Post: 19th Sep 2007, 14:09 -
what's up with nero??? should i leave it alone???
By offensekilla in forum Authoring (DVD)Replies: 3Last Post: 30th Aug 2007, 08:32
