Hi guys... was puzzled by a question asked by a friend recently and decided to seek help from experts here instead haha![]()
Supposedly, he has 2 different file types of the same filesize. One supposedly an *.avi and the other of mpeg4 compression (*.mp4) .
Which one would be of a better quality if they are of the same filesize. Or perhaps, which filetype would you guys prefer.
Thanks alot =))
.avi is a container, not a compression type. You can use countless different compression codecs within the avi container, and every codec has different quality compression ratios, as well as various different advantages and disadvantages. There's really no way to answer your question. Your avi and your mp4 file literally could be the exact same file just stored in different containers.
If you are still interested in getting some information about this specific avi file compared to your mpeg4 file, then you need to see which codec was used for compression on your avi file. You can load your avi into VirtualDub and hit file/file information to see this. If that doesn't work gspot will.
Advice: vhs to mpeg 4, or DVD to mpeg4
By yogohj in forum Capturing and VCRReplies: 19Last Post: 28th Feb 2012, 09:15 -
Expert advice needed regarding mpeg2 (ts) to mpeg4 (h264) encoding issue
By janvandenberg in forum Video Streaming DownloadingReplies: 16Last Post: 13th Dec 2011, 18:52 -
Advice needed on issue with AVI screen ratio
By Ric76 in forum EditingReplies: 4Last Post: 10th Aug 2010, 07:30 -
Media PC Advice Needed Please
By jaffacaique in forum Capturing and VCRReplies: 1Last Post: 24th Apr 2009, 22:06 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
