Hello...
I wanna burn my videos on a dvd.
The Videos are PAL (480*576) & NTSC (480*480) sizes.
I wanna put ~50 videos on 1 dvd. Space works...
Also i wanna mix NTSC & PAL Tracks.
Now i have some questions:So here is what i did:
- SVCD2DVDMPG:
First do a patch header change (1st header) to 720.
- DVD-LAB:
As said in some posts here dvdlab doesnt needs a headerpatch, it does for me. It doesnt accepts none patched videos (No DVD Sizes)
So i open all patched videos in DVDlab...
I need to say that all thumbnails that are shown in DVDlab have the half GREEN picture... (also known from other users)
I author the DVD and ignore the NTSC/PAL mixture errors...
- SVCD2DVDMPG:
I repatch the .vob files (1st header) to a 480 size.
- BURN
The files with Nero
I tested it in Standalone DVD Player:
All Videos work, no problems cause of NTSC/PAL mixup.
Some videos are Full Screen, and the most are normal size (480) and the right side of them is black.
How could i fix that problem?
How can i do it that DVDlab has correct Thumbnail Pictures (NO GREEN)?
Why do i need the header patch, when others dont...
Would be pleased if we can get a nice discussion here...
Thx 2 all / btw... superb software
Haha...
I fixed it.
I applied a ENTIRE file header repatch.
Now it works!
Something that doesnt work is:
I added also a DVDR Video (Full 720 Resolution)
And after header repatch it doesnt display anymore on DVD Player
Anyone here could explain me why my DVDLab "hover" menu doesnt work.
The selections keep the same color
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
6 episodes divx -> 1dvd
By TWDuke in forum Newbie / General discussionsReplies: 7Last Post: 8th Sep 2008, 17:54 -
Cutting Vids Help
By nldnboi in forum EditingReplies: 1Last Post: 2nd Oct 2007, 20:12 -
Fix Bad Header/Bugs in an .avi divx file
By krisbee in forum LinuxReplies: 3Last Post: 24th Sep 2007, 07:54
