When i insert the Sony Vegas 5 disk, nothing happens. So i go to Start>Run>Browse and i find the .exe file. I then try to open the file and i get the error "This Operating System does not support this Application."
How do i sort this out?![]()
rankz
1. Read the manual and see what OS'es Vegas supports.Originally Posted by rankz
2. See what OS you're running.
3. If the results of (2) are not supported by the results of (1), change your OS.
(and you might want to fill out your profile while you're at it)Fight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires! -
Vegas will install this for you. It will prompt to install. Possibility that rankz is not logged in as Admin, or maybe anti virus needs to be turned off.Vegas 5 requires the microsoft .NET framework.
@ rankz,
The profile (computer specs) is there for a reason. If you had filled it out, your problem could have been more accurately addressed.Geronimo -
I'm actually running Vegas 4.0e. When I upgraded from 4.0c the .NET compatibility was added (I guess). It ran ok without it (.NET), but it was recommended to download .NET from Microsoft or Sony. Good idea to put it on the disk, saves a lot of time for a dial-up user.
I don't know what it's for, I guess I haven't used the feature that needs it, seems to work the same as before.If it works, don't fix it. -
it will not install on ME at all and doest work as well on 2000
XP pro with 512 of memory and a min. of a 1.4 p4 is about realistic ..
System Requirements
Microsoft® Windows® 2000, or XP
500 MHz processor
60 MB hard-disk space for program installation
128 MB RAM
OHCI compatible i.LINK® connector*/IEEE-1394DV card (for DV capture and print-to-tape)
Windows-compatible sound card
CD-ROM drive
Supported CD-Recordable drive (for CD burning only)
Microsoft DirectX® 8 or later
Microsoft .NET Framework 1.1 (included on CD-ROM)
Internet Explorer 5.0 or later"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Sony Vegas 24 fps problem
By Reiden in forum EditingReplies: 6Last Post: 29th Jan 2012, 21:17 -
Sony Vegas problem
By francisco-drm in forum Authoring (DVD)Replies: 1Last Post: 18th Nov 2011, 07:16 -
problem with sony vegas
By buffaloboyy in forum Newbie / General discussionsReplies: 10Last Post: 24th Jan 2011, 21:06 -
Problem with Sony Vegas
By Beibin in forum EditingReplies: 4Last Post: 20th Jul 2010, 22:28 -
Problem with Sony Vegas 7
By DeaDudeA in forum EditingReplies: 6Last Post: 26th Jul 2007, 21:42
