I have 2 svcd mpegs. I joined them using tmpgenc, and then made a .m2v and a .mp2 file. i renamed the .mp2 to .mpa and made VOB files using Ifoedit. Everything worked, but then about half way through the movie, the audio messed up, it was totally off syncwhat could be the problem? how do i fix it?
thx,
dan
Hello,
I don't do svcds much but here's a thought. Why did you change the mp2? Mp2 is a legit dvd audio standard. Leave the mp2 file as is. Also, is your audio 48000? That is the dvd standard. Good luck.
Kevin
P.S. Are your two svcds the same video size and ratio?Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I renamed the .mp2 to .mpa because the guide said so. No, my audio is 41000, not 48000, but the guide said most DVD players should be able to play it. It played perfectly on my DVD player... don't know why the audio lost sync
Is there anything I can do?
Dan -
Dont join the mpgs,just author them as separate clips on the same track and they will play straight thru.
Try tmpgenc dvd author,it will join both files properly in the same track.
a good program for editing and/or joining mpeg files is womble mpeg-vcr. There is a trial version you can download to see if you like it. I use it often and have never had any audio sync problems joining files. Tmpgenc is an awesome video encoder but just isn't very good for doing editing.
Donadagohvi (Cherokee for "Until we meet again")
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 17:38 -
playing mpegs on a dvd player
By fromunda kid in forum Video ConversionReplies: 8Last Post: 9th Mar 2008, 13:30 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 03:32 -
Extracting MPEGs from defective DVD's
By TPFKAS in forum Video ConversionReplies: 3Last Post: 26th Sep 2007, 03:01 -
Xvid to svcd + burn...
By Crapozo in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2007, 06:07
