Hi,
I capture some music video on SVCD resolution 480*576 interlaced.
I'd like encode my capture to DVD format (720*576) so I use the following AviSynth Script.
The conversion is good but some motion seems to be "duplicated" probably due to the resize.Code:video=Avisource("d:\capture.avi",false) audio=WavSource("d:\capture.wav") audiodub(video,audio) LanczosResize(720,576)
So, is it better to 1) deinterlace, 2)resize, 3a) encode as progressive, 3b) encode as interlaced.
Which avisynth filter is the best to deinterlace and the faster one.
Thx.
Do not deinterlace.
I always use Procoder for my resizing.Want my help? Ask here! (not via PM!)
Second the 'don't deinterlace' suggestion: (a) I think DVD format video should be interlaced anyway (?? I see no other reason for it being 576 line 25fps on PAL) and (b), as your output is at the same height as your input, the resize shouldn't affect the interlaced fields.
KMPlayer and FFDShow deinterlace - how to get "bob" effect working?
By ANOther1676 in forum Software PlayingReplies: 3Last Post: 18th Feb 2011, 08:47 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 21:50 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 20:01 -
vdub "blend" deinterlace works, but now lines are jagged
By italo4ever in forum Video ConversionReplies: 3Last Post: 29th Jun 2009, 23:35 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 09:08
