Hello all, first post,
Last weekend I videod my mates wedding using his parents new Cannon 630i digital camcorder. I now want import that into my G4 (digital audio edition) and edit it using Final Cut Pro.
I have read on the web that Final Cut operates through firewire from the camera. According to the Canon web site the camera comes with a USB cable (which I haven't got but can get hold off).
So my question is can either Final Cut work with a USB cable or if I buy a firewire cable will this camera work with it? I am pretty sure it will but I want to be certain.
Thanks Alan
don't transfer your video using USB period. You will lose timecode- Basically, look to see if your camcorder has a firewire out (it will be 4 pin) That is the correct way to get video from a camcorder to a computer digitally. The USB option isn't cool. I would go with firewire unless you can't (not sure about that camera).
"What's a matter Colonel Sanders???? CHICKEN???!!!! -
That camera has Firewire. Get the 4-pin to 6-pin Firewire cable to connect it to your Mac.
If I am not mistaken I thought that the usb was only to transfer still pcitures from the memory cardOriginally Posted by Chief_1975
Taken fromThe powerful Canon 20x zoom lens is ideal for recording even distant subjects. The USB interface and powerful Canon software makes it simple to transfer still images from the memory card. A high resolution 800k pixel CCD and DIGIC DV signal processing ensures high quality video and still images.
http://www.griffler.co.nz/cgi-bin/nz_store/00292.html
use a firewire cable
see specs
http://www.shopping.com/xPF-Canon_MV630i
Check www.pricewatch.com
They have some 3ft cables for $2!!! -
Thanks for the replies guys, I think the same 4 pin port on the camera is used for the connecting the USB cable as well as the Firewire cable?
Have order a firewire cable, live in the UK so not a cheap as the 2 dollar one!
I will let you know how I get on.
Thanks again -
That doesn't sound very likely, but it's possible I suppose ... (?)Originally Posted by Chief_1975
its got a differnt pin config so usb and firewire arent compatible (also it wont fit)
http://www.networktechinc.com/technote.html
(4 pin version of firewire doesnt carry power like the 6 pin version does and usb carries 5v power through one of the 4 pins)
Also the usb is only for transferring the still images from the memory stick with that particular camera (As far as I know)
Final Cut X
By Tom in HD in forum MacReplies: 1Last Post: 29th Oct 2011, 09:35 -
Why Mac? Why Final Cut?
By codemaster in forum EditingReplies: 26Last Post: 15th Mar 2011, 00:17 -
Final Cut to ProTools
By perik in forum MacReplies: 2Last Post: 30th Mar 2009, 16:28 -
Final Cut Express- How To
By ker-plop in forum MacReplies: 2Last Post: 8th Apr 2008, 20:41 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
