I have the original Star Wars movies on VHS (not the ones with the extra crap) and I want to put them on DVD's. Should I just hookup my VCR and do a standard analog capture then use my software to transfer to DVD?
OR, is there some super-duper way to make them, look and sound better than a regular old capture/transfer/burn?
Thanks!
Timebase correctors (TBC), proc amps, DNR (in SVHS VCRs).
The laserdiscs are better.Want my help? Ask here! (not via PM!)
Hello,
The normal analog capture is your best bet. Your source won't really be improved, just preserved. Use the highest setting that will fit a dvd. If you want you can record at the highest dvd setting and then shrink the authored vobs later. That might be a little better than the lower settings (that fit on a disc without shrinking).
I've still got to do that with my copies (full screen not widescren
). My first try had audio synch problems. I'm better at capturing so I just have to sit down and do it again. Best of luck.
Kevin
P.S. I hope your still planning on buying the special edition dvds in September. Nothing compares to true professional 5.1, extras be damned. It's still STAR WARS!!!!!!!! (Long live Lucas
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
You're not alone. https://www.videohelp.com/forum/viewtopic.php?t=102812&highlight=star+wars+conversion
If you've got a spare day or so to read all that maybe you'll get a few ideas. -
Toughest part will make them look good since most are 2+ hours. You may have to encode at a bitrate of 4kVBR or less to make 'em fit on one disk.
At 2hrs 15 min movie you can only encode at 4288 max bitrate with 224kbs audio capture (MPEG1L2)... if you use PCM audio your video bitrate will be even lower.
help with star wars saga br
By kn5150 in forum Blu-ray RippingReplies: 9Last Post: 21st Sep 2011, 17:55 -
What was your favorite star wars movie?
By johns0 in forum PollsReplies: 19Last Post: 3rd Jul 2011, 20:39 -
Edit Video Like in Star Wars ?
By SEJedi in forum EditingReplies: 15Last Post: 28th Apr 2011, 10:50 -
Star Wars 3D
By stiltman in forum Off topicReplies: 20Last Post: 26th Oct 2010, 20:11 -
Original Star Wars Limited edition dvd not anamorphic. How would I convert
By shroomalistic in forum Authoring (DVD)Replies: 46Last Post: 21st Aug 2009, 22:13
