I am authoring a home dvd, using DVD-lab. The source files are D/2 (352x480) mpeg2, and I use DVD-lab to demux, an intro movie, a menu, and two more movies.
Since DVD-lab isn't talking to my DVD-RW, I am using NTI to burn a "data DVD" of the two folders created by DVD-lab when the movie is compiled.
Previously, I've used DVD-lab to burn this type of movie with PNY CD-R media in mini-DVD format, and it works fine in my standalone DVD player. This project is 1.8 GB, so I'm using Sony DVD-R media. The disc plays fine in my laptop (tested two different ones), but not in my home standalone Mintek (cheap Best Buy) DVD player. In the DVD player, I get vertical stipes (bars) of black and white. It seems to act like it's playing (gives some indications when I press certain buttons on the remote), but I don't get anything useful, and can't get a menu or title screen.
Any ideas what I'm doing wrong? Any info needed to help me diagnose this? I checked the media, and it seems to be okay--since it works in the laptops.
Can this be that my DVD player doesn't like the Sony DVD-R media, where it doesn't mind the PNY CD-R stuff?
Or, does this sounds like an authoring problem with the D/2 material (which works on CD-R stuff on the player)?
Or, can this be using NTI to burn the folders to the DVD-R disc?
thanks for you help,
Tim
I may be wrong but a data DVD won't play in your stand alone player. Try creating an ISO of you 'movie' and then use DVD Decrypter to burn it.... another test .Originally Posted by tmw
The data I am burning is the AUDIO_TS & VIDEO_TS folders created when compiling the project in dvd-lab. I thought that a 'movie' DVD is really just a data DVD with a specific structure, and by writing that structure, I should make a DVD that works.Originally Posted by DVD_Ripper
Please, let me know if I'm off in my assumption, as I don't want to waste too many DVD-R's (and have noted to myself I really need some DVD-RW to do testing on all this.
Thanks,
Tim -
It is a data DVD, but needs a certain UDF/ISO TOC. There are many different types of data DVDs, with different types of UDF, ISO, and Joliet descrypters, DVD-VIDEO needs the correct settings for each type.
Use imgtools to create an image file of your VIDEO_TS/AUDIO_TS folders then burn with DVD Decrypter.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
Thanks for clarifying. I'll try these out tonight, and hopefully get a good disc. I appreciate everyone's help... there is so much information, I've been wading through, and it's good to be able to ask someone.
Tim
Standalone player will not play DVD
By Chala in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2010, 04:09 -
HT - dvd player in the pc or a standalone?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 5Last Post: 6th May 2010, 08:39 -
OGM on standalone DVD Player
By BlundaKat in forum Video ConversionReplies: 1Last Post: 29th Sep 2009, 08:03 -
Xvid AC3 file playback problem on Standalone DVD player
By kamol88 in forum Video ConversionReplies: 2Last Post: 21st Mar 2009, 04:38 -
Problem with playing DVD in standalone player
By tngolfn in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2007, 18:41
