if a original dvd disc bitrate is 6000 and i want to encode a 25 min avi video with TMPGenc at 8000 bitrate will it consider as a xdvd or just as same as original dvd but with higher bitrate?????
Results 1 to 11 of 11
DVD supports up to 9.8mbps for video bitrate, any higher than that would make it an xDVD.
nine point eight megabits per second. (9.8Mbps)
or nine thousand eight hundred kilobits per second.(9800Kbps) -
turn off the wizard and adjust the bitrate manually in the first options tab.
wait for it....Originally Posted by flaninacupboard
Should we add at this point that making the bitrate 9800 is not going to "enhance" the quality at all and is probably overkill ?
The other thing is that the combined bitrate can go to 9.8MBit. That is, audio + video combined, not just video.If in doubt, Google it. -
http://dvddemystified.com/dvdfaq.html saysOriginally Posted by jimmalenkoandAfter system overhead, the maximum rate of combined elementary streams (audio + video + subpicture) is 10.08.I agree with you about it being overkill in most situations thoughMaximum video bit rate is 9.8 Mbps
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
