So i have a few dvd image files of extension .img and .iso, and when i burn them using nero and then try to play them in my ps2 i get a tv system error which i have been told means that the dvd is coded to the wrong region. So basically what i need to do is take the region coding out of the dvd image file.
Heres what i've tried so far. I've tried taking one of the burned dvds and using dvdshrink to make a bakeup copy of it, then selecting the region free mode, but that didn't work. I've also tried removing the region coding from the .ifo files in the video_ts folder of the dvds but that didn't work either. I also tried the stupid code to unlock my ps2 for all regions but that didn't work either.
Anyways if someone could provide me with step by step instructions on how to do this, or just point me in the right direction
You sure this isn't a PAL-NTSC issue rather than a region coding issue.
Well how exactly would i know if it was a PAL-NTSC issue? When i burn the images i can play the movies fine in my pc dvd drive which has been unlocked for all regions, but both my ps2 and my roomates dvd player give me region errors when i try the burned dvds in them.
Soniq QMD80B Portable region coding firmware update
By twiztid in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Aug 2010, 04:44 -
Region coding on burned disks.
By sambat in forum Authoring (DVD)Replies: 6Last Post: 14th May 2010, 17:59 -
Cannot watch DVD on my DVD player after removing region restrictions
By robertin75 in forum DVD RippingReplies: 5Last Post: 17th Apr 2010, 11:27 -
BluRay Region Coding Announced - Japan & US Same Region
By GullyFoyle in forum Latest Video NewsReplies: 57Last Post: 18th Dec 2008, 16:55 -
DVD Region Coding
By jasej in forum Authoring (DVD)Replies: 5Last Post: 27th Jul 2007, 08:59
