I've seen this a lot on this forum. How do people insert screen shots of their problems? Can anyone explain it to me.....in simple terms, Programs, etc....I have Adobe PhotoshopCS as my photo software or just let me know how you guys do it. Thanx
Results 1 to 11 of 11
What We Do In Life, Echoes In Eternity....
to take a screenshot:
some apps have a built in button for saving a screenshot to file (such as dvdinfopro) but mostly what you need to do is press the "print screen" button and then open your favourite picture editing software (even windows "paint will do) and paste it there - the screenshot is already on the clipboard - just press "paste".
to put a picture in your post browse in the section below where you write the actual post: it says upload image - browse and find your image and then write in the post *img*filename.gif*/img* filename.gif being the picture you selected when browsing. replace * with bracket [ or ] .
that should do the trick.With all due respect... and there is respect... -
ok thanks....
What We Do In Life, Echoes In Eternity.... -
I have dvdinfopro but when I hit the save current view it saves the infopro view. What I want to do is save a screenshot of a properties info pop up (ie click on jpeg/foleder and click properties), to show someone what I'm having a problem with. So how do I show this?
You can do a PrintScreen and then paste that into your paint program... resize to about 300 or 400 pixels wide ... save to jpg and you are good to go (make sure it is below 50k)... you can adjust the JPG quality to keep reducing the size should that be necessary
How do I do a print screen.....I feel like such a newb right now.....
On your keyboard above the insert key is a key labeled Print Screen, press it, that copies the active window onto Windows clipboard, then press control then the v key to paste it .....
1) START --> ALL PROGRAMS ---> ACCESSORIES. Click on "Paint".Originally Posted by Denvers Dawgs
2) Highlight the window (or whatever) you want to "print".
3) Press the "Print Screen" key on your keyboard.
4) In the "Paint" program (at the top), click "Edit" and then "Paste" (or simply press the CTRL and V keys at the same time). -
And to capture just the active window or app (instead of the whole desktop) press the ALT key while pressing Print Scrn
Thanx I found the Print Screen key.....I knew it was something easy like that, but I just couldn't figure it out....sometimes I feel like a newb all over again....lol....thanx all
Toshiba Satellite black screen no post
By MJA in forum ComputerReplies: 6Last Post: 3rd Feb 2012, 20:41 -
VLC (or better?) for grabbing still shots
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 8Last Post: 22nd Jun 2010, 20:58 -
Looking for a really nice codec to capture screen shots as a video
By snafubaby in forum Video Streaming DownloadingReplies: 1Last Post: 31st Aug 2009, 06:43 -
Lots of shots on the screen at the same time
By fly37 in forum EditingReplies: 3Last Post: 4th Aug 2008, 07:55 -
English subtitles for Hot Shots
By Altruist in forum SubtitleReplies: 10Last Post: 31st Jan 2008, 02:22
