I have a folder with only VOB's in they play fine in Mplayer but if I try to make a DVD with Toast it won't encode it says error with source material.
Should I only have VOB's or should there also be IFO and BUP files??
Would you recommend re-authoring the DVD?
Thanks in advance.
recommend.... you have to!
try toast with just one of them and see what happens
save as disk image instead of burning
otherwise, demux and reautor in sizzle -
Kindly ignore this. I asked a stupid question, then searched for the answer. I'll now retreat back to my dark hole.
Droplets of yes and no in an ocean of maybe. -
you didnt start the post.
if you have the most up to date toast, it shouldnt
yes, you have to get the older version of sizzle
have fun -
No, but I said something and asked a follow-up question about VOBs. Rather than allowing my stupidity to infuriate others, I edited my message.Originally Posted by galactica
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Best way to convert NTSC .VOB --> PAL .VOB
By macuser1960 in forum ffmpegX general discussionReplies: 1Last Post: 9th Mar 2008, 16:43 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 05:44
