  1. Member dudeman316's Avatar
    Dec 2002
    Up Soon!
    Ok this is what I did, I borrowed a movie that is a Flipper & i ripped both sides to my hard drive then merged the 2 sided together with the Reauthor function of DVDShrink. BUrned it & it works fine. I then decided to add menus to this to give it a lil more life. So i loaded all the files into TMPGEnc DVD Author. After creating the project & burning it, I noticed that the Sub Titles were gone. Is there any way I can add these back to the movie?? Or do I need to use different software?? Or what?
    Father knows best.
    you can't use tmpgenc dvd author if want to keep the switcable subtitles. you could try dvd-lab pro.
  3. Member dudeman316's Avatar
    Dec 2002
    Up Soon!
    Thanks Baldrick, I will have to give it a try. Can you tell my why some of the menu options I maded in tmpgenc dvd author will hang or halt the standalone player?? It is mainly the movie trailors I added to the Menu.
    Father knows best.
  4. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    you could try using Mark's Tray DVD player as that may tll you what the errors are as it sometimes pops up to tell you
    if not you can watch the parameter values and see if everything is OK and it also saves a log telling you exactly how thenavigation is working, what is playing and what values it's changing
    its a must have tool
    I know Baldrick mentioned DVDLab PRO. I know in older version it would not allow subtitles but there was a DVDLab guide showing you how to add subs after authoring (2Cool & Maa I think) but I dont know if this is now an option in DVD Lab to add subs as I haven''t used it in months
    are the subs in the processed VOB's after using tmpgenc?
    what about DVDAuthor?
  5. Member dudeman316's Avatar
    Dec 2002
    Up Soon!
    thanks MackemX i will try this when i get a chance
    Father knows best.
  6. Ok this is what I did, I borrowed a movie
  7. Member dudeman316's Avatar
    Dec 2002
    Up Soon!
    Yeah my full intentions was to make a backup copy for the person I borrowed it from
    Father knows best.
