I was wondering if anyone has any infromation on the new 1080i dvd players? If so I would sure like to know. I looking for a mulit-player, pal and ntsc. I guess just a all around great player. Thanks Darren.
I have a Bravo D1. I like it... the PQ is stunning using the DVI on my Samsung 46" DLP.
There are a number of affordable upscaling DVI players now. The Bravo D2 just came out. There is the new Zenith 318 (it scales to HD formats through it's component outputs, if you don't have a DVI on your HDTV). Samsung's HD841 is in Best Buy already. There's a LiteOn (2001, I think). Momitsu 880 is another one - it can be hacked region-free pretty easily from a hidden menu using the remote control (it also scales to HD formats through the component outputs). -
Thanks handyguy and gshelley61 , I will check out your suggestions. I'm using a 57" Hitachi hd tv.
The most popular upscaling DVD player with DVI, although it will upscale in its component output too is the Zenith DVB318. Just check out the thread at avsforum.com - dvd player section, they're raving about it esp. for the price. I think you can get it for $160 here.
http://www.gochnauers.com/tv_vcr/tvvcr.html#dvd
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37 -
media player 1080p vs 1080i
By mishtag in forum Media Center PC / MediaCentersReplies: 25Last Post: 12th May 2010, 00:25 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 17:25 -
1080i .ts or .mpg to DVD help
By delpis in forum Authoring (DVD)Replies: 4Last Post: 8th Jun 2007, 20:49 -
1080i Upconverting DVD Player Through Component Inputs
By Teutatis in forum DVD & Blu-ray PlayersReplies: 5Last Post: 16th May 2007, 01:16
