I tried the Sharp DV-HR300 at fry's and found turning on the machine takes at 20-30 seconds. I assume the machine is not defect. Also reading in a DVD/CD took about 15 seconds which also very slow.
How fast are other recorders like the JVC?
Here are some tests I did with Sharp regarding format support:
Sharp DV-HR300:
DVD+R: playback ok
DVD-R: playback ok
DVD-R PAL: disc not supported
VCD-PAL: playback ok
Results 1 to 14 of 14
I have an M10S and the numbers you posted sound about right (I have "power save" set to "on", though).
Regardless, it doesn't matter much to me how long the machine takes to start up or read a disk. What I really care about is the delay after hitting the record button. I've read a few accounts of considerable lag times with other machines. My M10S, however, starts recording almost immediately after hitting the record button. -
So it takes 15-20 seconds on JVC as well to startup? I wonder why.
The Sharp might be because it's reading HDD contents. -
Yes, but that's because I have "POWER SAVE" enabled. Thus, the machine sort of goes into hibernation; even the clock is inoperative. It takes a few extra seconds to "wake up".Originally Posted by Lucien
This is the US version. Yes it seems weird it can play PAL SVCD but not PAL DVD. However I saw exactly same thing with an older JVC player.
every writer recorder I use takes time to recognize what type of disk you put in it.
Desktop RCA takes about 10 seconds to read / recognize disk.
PC based TDK takes 6-10 seconds to recog disk -
Ditto. But, as I stated earlier, apparently some recorders take several seconds (or longer) to start recording after the record button (on the remote or the unit) is depressed. Not good if that information is, indeed, accurate.Originally Posted by handyguy
Sure but the difference is huge. My JVC player takes max. 5 seconds (as does my computer sony burner). The Sharp in the store took at least 15 seconds (almost seems it was hanging). How long do the JVC recorders take to recognize the disc?
Yes pressing record should be ideally instant. With the Sharp I would miss at least 30 seconds if it was turned off. -
I've been using -RWs and it takes about 15 seconds for my M10S to read them in.Originally Posted by Lucien
You lost me. How, exactly, would you miss 30 seconds? I mean, if you were planning to record something (no matter what the source), wouldn't you already have the machine powered on and a disk loaded? Sorry, if I'm being obtuse here.Originally Posted by Lucien -
If I'm just turning on the TV and find something that I want to record and it's already running then you lose time.Originally Posted by tag
But in general I found that the Sharp always reacted to the remote input with a lag (1 second). Quite annoying if the remote feels disconnected from what the machine is doing. -
I got it now (finally
). But, personally, if I were concerned about missing part of a show, I'd be looking at recorders with HDDs.
No POST during startup
By mysts in forum ComputerReplies: 5Last Post: 25th Oct 2011, 01:47 -
XP OS selection at startup.....
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2009, 00:55 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Errors on startup
By johnbrigden in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd May 2007, 05:14 -
Error on startup
By bush in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 22nd May 2007, 18:30
