Can anyone recomend a software package to convert vr format video that I made with my Sansui dvd recorder over to dvd format that can be copied using my pc?
Hello,
I don' believe you need to. Dvd uses vobs to store video. Pop the disc in and you should see a video_ts folder with several .vob files. Those are the video files. Use any ripper like dvddecryptor to copy them to your harddrive. Then you can use any program to manipulate them however you need to. Hope this helps.
VR mode makes VRO files, not VOB.
They're just MPEGs.Want my help? Ask here! (not via PM!)
Is this what you're looking for?
http://www.ulead.com/learning/dmf/dmf3_03_1.htm -
The Ulead DVD Movie Factory has a trail verison and will import the VR files but has a limitation of the digital sound with the trial verison. Try it. I also have the Sansui recorder and have be able to use Sonic myDVD to import the VR files off of DVD-RW and then edit and burn home videos with menus. It didn't work until I was able to download the UDF reader from Sonic. Sonic support is not helpful, it's web/e-mail based and I didn't get any answer to my support questions. Your mileage may vary.
Good Luck.
how to convert dvd to other format
By steelmaster in forum Video ConversionReplies: 2Last Post: 27th Apr 2012, 14:26 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 02:06 -
which is the best software to import/convert VHS to Digital format ?
By james_patageul in forum Capturing and VCRReplies: 3Last Post: 3rd Feb 2009, 20:08 -
Any free software to convert a recorded dvd into youtube format
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 4Last Post: 5th Aug 2007, 13:07 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
