I'm trying to import mpeg2 video clips into iMovie and tried to convert the files with FCP to DV but keep getting error number 34 when I try to export using QuickTime conversion/DV
Is there an application that will convert the mpegs to DV?
Any info appreciated.
Dave
Originally Posted by mephoneno
dskFulErr
Disk full
I don't have any trouble using QT to convert MPEG2 to DV. Are you sure you have enough disk space? DV = 13+ GB per hour. -
Originally Posted by TugBoat
! I was trying to convert a 40 second clip...I've got a little more than 10GB available...
Thanks for the feedback.
I'll keep trying.
Dave -
There's probably a problem with either your system or the file. I can import a mpeg2 stream or VOB directly into iMovie 4 and FCP 4. iMovie automatically converts it, FCP converts to DV after rendering, and I have never had the 'error 34' while converting mpeg2 to DV with QT. Check your source file.
Editing MPG2
By danielmak in forum MacReplies: 16Last Post: 17th Feb 2010, 17:28 -
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 14:05 -
Convert video from 2-disc dvd to one mpg2
By gamingexpert13 in forum Video ConversionReplies: 12Last Post: 17th Oct 2007, 04:59 -
Convert mpg2 to mpg for Movie Maker
By Cattis in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 13:01 -
MPG2 or MPG4???
By JennyBear in forum Newbie / General discussionsReplies: 7Last Post: 1st Aug 2007, 17:33
