I want to fit more video on the disc. The content is from camcorder so the audio is low quality. I am considering the following:
1. Compress with mp2. Is that OK with most settop players?
2. Use lowre frequency PCM. The camcorder is only 32K, I think. The DVD standard is 48K. Can I use 32K instead?
Thanks!
You need to lower the bitrate, not the frequency.Originally Posted by cheerful
1) mp2 will work in all PAL region players. Support is optional in NTSC regions.
2) for DVD compliance audio must be 48khz. The camcorder can probably record audio at 48khz too, so change the setting, there is no benefit to 32khz. Use of PCM audio will take up lots of space, so stick with mp2 or if you are in an NTSC region, consider Ac3. 256kbps for 2 channel will give excellent quality for either format.
An app that views audio's frequency (Hz)?
By firebo14 in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2012, 20:34 -
Application to lower audio gain of MPEG file?
By headless chicken in forum MacReplies: 6Last Post: 26th Dec 2008, 09:41 -
Pinnacle Studios 11 - Low Frequency Audio Hum
By notheldge in forum Capturing and VCRReplies: 9Last Post: 15th Aug 2008, 13:07 -
4+hour DVD9, lower audio bitrate for better video?
By sdsumike619 in forum AudioReplies: 10Last Post: 24th Oct 2007, 12:24 -
audio PCM to MP2 while retaining DVD menus
By navels in forum Video ConversionReplies: 2Last Post: 20th May 2007, 16:51
