It seems to me that each time I use DVDINFOPro, i get read errors on different sectors of the same disk. Using Nero CDSpeed usually gives me a clean read on the same exact disks (but not always). However, when played on my stand alone DVD player, the movies play fine, but will skip/freeze on my portable DVD player.
These are with RICOHJPNR01, CMC, and MCC disks. All 2 DVD readers (a Sony and a BTC - can't remeber model numbers), an Optorite DD0401 and HP 300i gave the same "consistent" inconsistencies.
Anyone have an idea of what's going on?
are these errors on different sectors close toghether? sometimes it finds different sectors of the same block defected but if it's really different sectors then it is weird.. i just ran a check on a disc which had 13 errors and now it has 7... it's not accurate science - just an estimation of data validity.
With all due respect... and there is respect... -
THE CMC disks may just be unstable (they are at the bottom of the heap regarding disks)
MCC and RICOH are good and should not exhibit this type of unstability. Possibly a dirty lens -- are they older drives? -
Well, the errors are random, sometimes at the beginning of the disk, sometimes at the end - rarely do I get error blocks in the exact same block. The drives are about 6 months old. I'll run a lens cleaning disk on them and see, but I've had this problem for a while, so I'm not sure if dirty lens is the problem.
I think NERO has a scanning program as well... you may want to give it a try... also, check for a later version DVDInfoPro
IsoBuster settings for read errors
By 1337assassin in forum Newbie / General discussionsReplies: 8Last Post: 23rd Oct 2010, 12:20 -
How to Convert VOB file from DVD with ignore read errors
By designbuyers in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:17 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Is it possible to overcome read errors in homemade DVD?
By geepondy in forum DVD RippingReplies: 8Last Post: 19th Jun 2007, 22:21 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
